PostGIS 3.4.3 Released
Paul Ramsey pramsey at cleverelephant.ca
Wed Sep 4 12:58:03 PDT 2024
http://postgis.net/2024/09/PostGIS-3.4.3/
The PostGIS team is pleased to release PostGIS 3.4.3! This release is
a maintenance and bug fix release.
Issues Closed:
 - #5766, Always report invalid non-null MBR of universal face (Sandro Santilli)
 - #5709, Fix loose mbr in topology.face on ST_ChangeEdgeGeom (Sandro Santilli)
 - #5698, Fix robustness issue splitting line by vertex very close to endpoints,
          affecting topology population functions (Sandro Santilli)
 - #5649, ST_Value should return NULL on missing band (Paul Ramsey)
 - #5677, ST_Union(geom[]) should unary union single entry arrays (Paul Ramsey)
 - #5679, Remove spurious COMMIT statements from sfcgal script
          (Sandro Santilli, Loïc Bartoletti)
 - #5680, Fix populate_topology_layer with standard_conforming_strings
          set to off (Sandro Santilli)
 - #5589, ST_3DDistance error for shared first point (Paul Ramsey)
 - #5686, ST_NumInteriorRings and Triangle crash (Paul Ramsey)
 - #5666, Build reproducibility: timestamps
          in extension upgrade SQL scripts (James Addison)
 - #5671, Bug in ST_Area function with use_spheroid=false
          (Paul Ramsey, Regina Obe)
 - #5687, Don't rely on search_path to determine postgis schema
           Fix for PG17 security change (Regina Obe)
 - #5695, [address_standardizer_data_us] standardize_address
          incorrect handling of directionals (Regina Obe)
 - #5653, Do not simplify away points when linestring doubles back on
          itself (Paul Ramsey)
 - #5720, Correctly mangle special column names in shp2pgsql (Paul Ramsey)
 - #5734, Estimate geography extent more correctly (Paul Ramsey)
 - #5752, ST_ClosestPoint(geography) error (Paul Ramsey)
 - #5740, ST_DistanceSpheroid(geometry) incorrectly handles polygons
(Paul Ramsey)
 - #5765, Handle nearly co-linear edges with slightly less slop (Paul Ramsey)
 - #5745, St_AsLatLonText rounding errors (Paul Ramsey)
