Migrating TIGER from Oracle to POSTGIS
Sandro Santilli
strk at kbt.io
Wed Mar 19 10:18:38 PDT 2025
On Wed, Mar 19, 2025 at 12:02:36PM +0000, Ayorinde O Adesugba (CENSUS/DITD FED) wrote:
> Is there a way to run a particular test (or tests)?
For Topology we only have "regress tests", which can be run with the
regress/run_test.pl script (run with no args to get help text)
Example run of a single test from a build dir:
${srcdir}/regress/run_test.pl \
--topology \
-v \
${srcdir}/topology/test/regress/createtopology
You'll need to have run `make staged-install` before, for the test
script to find the postgis libraries and enabler scripts.
> I am trying to modify a particular test, and it would be great
> to focus on that test rather than kicking off the full suite.
Makes sense.
--strk;
