Migrating TIGER from Oracle to POSTGIS
Ayorinde O Adesugba (CENSUS/DITD FED)
Ayorinde.O.Adesugba at census.gov
Wed Mar 19 10:44:12 PDT 2025
Census - General
Thanks.
I am facing a more interesting challenge. The topology_comments.sql needs to be updated, so that it references int8 (bigint) instead of integer for a few functions that need to be updated.
How do I trigger the comment rebuild. I have been stuck on a test for over 2/3 hours cause the comment on the function no longer lines up with the new signature for the function.
Thanks,
Ayorinde Adesugba, Special Assistant to ADC,
Spatial Data Systems, DITD
U.S. Census Bureau
O: 301-763-2057 | M: 202-381-8034 | F: 301-763-4710
ayorinde.o.adesugba at census.gov<mailto:ayorinde.o.adesugba at census.gov>
census.gov<http://www.census.gov/> | @uscensusbureau<https://twitter.com/uscensusbureau> | 2020Census.gov<https://2020census.gov>
Connect with us on Social Media<http://www.census.gov/about/contact-us/social_media.html>
Census - General
Sent: Wednesday, March 19, 2025 13:18
To: Ayorinde O Adesugba (CENSUS/DITD FED) <Ayorinde.O.Adesugba at census.gov>
Cc: postgis-devel at lists.osgeo.org <postgis-devel at lists.osgeo.org>
Subject: Re: Migrating TIGER from Oracle to POSTGIS
On Wed, Mar 19, 2025 at 12:02:36PM +0000, Ayorinde O Adesugba (CENSUS/DITD FED) wrote:
> Is there a way to run a particular test (or tests)?
For Topology we only have "regress tests", which can be run with the
regress/run_test.pl script (run with no args to get help text)
Example run of a single test from a build dir:
${srcdir}/regress/run_test.pl \
--topology \
-v \
${srcdir}/topology/test/regress/createtopology
You'll need to have run `make staged-install` before, for the test
script to find the postgis libraries and enabler scripts.
> I am trying to modify a particular test, and it would be great
> to focus on that test rather than kicking off the full suite.
Makes sense.
--strk;
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20250319/c0280066/attachment-0001.htm>
