PostgreSQL 18 PostGIS 3.6 installer Windows
Gandalf the Gray
pjduplooy.gis at gmail.com
Sun Oct 5 07:34:03 PDT 2025
Hi Regina
Thank you for the installer!! I appreciate it!
Just a couple of comments.
I selected the option to install the CURL_CA_BUNDLE, but it is not in the
installer. Rapid Environment Editor indicates that C:\Program
Files\PostgreSQL\18\ssl\certs\ca-bundle.crt does not exist.
Are you planning to build osm2pgrouting. I built it using MSYS but cmake
fails complaing about a lot of nonexistent folders. I followed your
instructions on
https://github.com/pgRouting/pgrouting/wiki/Building-on-windows-with-msys2-and-mingw64-(WIP)
Are you planning pgsphere?
Otherwise there are no issues at all.
Thanks again.
Pieter
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20251005/c0f1566c/attachment.htm>
