PostgreSQL 18 PostGIS 3.6 installer Windows
Regina Obe
lr at pcorp.us
Sun Oct 5 07:50:45 PDT 2025
Gandalf,
Hmm I’ll fix the CURL_CA_BUNDLE. Guess I missed including that. Probably won’t get to it until mid week.
Yap pgSphere I hadn’t had a chance to include since I was in such a rush, but yes I’ll include in next update.
Osm2pgrouting – Let me get back to you on this. But the plan is yes plan to include it, but I know Vicky was working on logistic changes to it, so it might be newer than the 2.3.8.
Cc’d users list in case others are interested, since this was mentioned there too.
From: Gandalf the Gray <pjduplooy.gis at gmail.com>
Sent: Sunday, October 5, 2025 10:34 AM
To: postgis-devel at lists.osgeo.org
Subject: PostgreSQL 18 PostGIS 3.6 installer Windows
Hi Regina
Thank you for the installer!! I appreciate it!
Just a couple of comments.
I selected the option to install the CURL_CA_BUNDLE, but it is not in the installer. Rapid Environment Editor indicates that C:\Program Files\PostgreSQL\18\ssl\certs\ca-bundle.crt does not exist.
Are you planning to build osm2pgrouting. I built it using MSYS but cmake fails complaing about a lot of nonexistent folders. I followed your instructions on https://github.com/pgRouting/pgrouting/wiki/Building-on-windows-with-msys2-and-mingw64-(WIP)
Are you planning pgsphere?
Otherwise there are no issues at all.
Thanks again.
Pieter
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20251005/9d5686c5/attachment.htm>
