3.7.0 dev version issues
Gandalf the Gray
pjduplooy.gis at gmail.com
Wed Aug 5 04:31:39 PDT 2026
Hi Regina.
Follow up question. Do I first overwrite with the PostGIS archive and then
the PostgreSQL one?
On Wed, Aug 5, 2026 at 11:42 AM Gandalf the Gray <pjduplooy.gis at gmail.com>
wrote:
> Hi Regina.
> The exe works fine. Its just the zip file. I will get the archive from the
> link you gave.
> Pieter
> On Wed, 05 Aug 2026, 09:01 Regina Obe, <lr at pcorp.us> wrote:
>> Sorry missed your message yesterday.
>> Did it work when you did the .exe install and it only failed when you
>> recopied the newer PostGIS 3.7.0dev binaries or are you saying installing
>> the postgis .exes broke your PostgreSQL install?
>> My guess is its one of the libraries that ships with PostgreSQL. I try
>> not to overwrite these. When you copy using the zip, you shouldn’t
>> overwrite them either but I include them just because in some cases EDB
>> calls them by a different name than what the postgis libraries are bound
>> to. If they are there they shouldn’t be overwritten cause there versions
>> are sometimes newer than the one I ship.
>> My suggestion – copy the binaries from -
>> https://www.enterprisedb.com/products-services-training/pgdevdownload
>> (the ones in the bin folder) and overwrite the ones in your bin folder.
>> Then try to start up your PostgreSQL 19 server.
>> *From:* Gandalf the Gray <pjduplooy.gis at gmail.com>
>> *Sent:* Wednesday, August 5, 2026 2:51 AM
>> *To:* postgis-devel at lists.osgeo.org
>> *Subject:* 3.7.0 dev version issues
>> Hi Regina.
>> I have tried the newest dev version of 3.7 (refer to my previous post on
>> Monday).
>> The issue with my PG 19 server not starting after copying over the files
>> into the folder that had PostGIS 3.7 installed with the exe (I am on
>> Windows) still remains.
>> Could you look into it?
>> Pieter
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20260805/636abdbc/attachment-0001.htm>
