3.7.0 dev version issues
Gandalf the Gray pjduplooy.gis at gmail.com
Wed Aug 5 02:42:56 PDT 2026
Hi Regina.
The exe works fine. Its just the zip file. I will get the archive from the
link you gave.
Pieter
On Wed, 05 Aug 2026, 09:01 Regina Obe, <lr at pcorp.us> wrote:
> Sorry missed your message yesterday.
> Did it work when you did the .exe install and it only failed when you
> recopied the newer PostGIS 3.7.0dev binaries or are you saying installing
> the postgis .exes broke your PostgreSQL install?
> My guess is its one of the libraries that ships with PostgreSQL.  I try
> not to overwrite these.  When you copy using the zip, you shouldn’t
> overwrite them either but I include them just because in some cases EDB
> calls them by a different name than what the postgis libraries are bound
> to.  If they are there they shouldn’t be overwritten cause there versions
> are sometimes newer than the one I ship.
> My suggestion – copy the binaries from -
> https://www.enterprisedb.com/products-services-training/pgdevdownload
> (the ones in the bin folder) and overwrite the ones in your bin folder.
> Then try to start up your PostgreSQL 19 server.
> *From:* Gandalf the Gray <pjduplooy.gis at gmail.com>
> *Sent:* Wednesday, August 5, 2026 2:51 AM
> *To:* postgis-devel at lists.osgeo.org
> *Subject:* 3.7.0 dev version issues
> Hi Regina.
> I have tried the newest dev version of 3.7 (refer to my previous post on
> Monday).
> The issue with my PG 19 server not starting after copying over the files
> into the folder that had PostGIS 3.7 installed with the exe (I am on
> Windows) still remains.
> Could you look into it?
> Pieter
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20260805/3aede442/attachment.htm>
