ERROR: Could not add geog_brin_inclusion_merge to brin_geography_inclusion_ops..null value in column "refobjid" (Re: Do you use PostGIS BRIN?)
Regina Obe lr at pcorp.us
Thu Feb 12 07:09:31 PST 2026
Justin,
Remind me do you always have this issue when upgrading older customers
(those who have been running PostGIS since at least PostgreSQL 9.3) or only
with some customers?
> -----Original Message-----
> From: Justin Pryzby <pryzby at telsasoft.com>
> Sent: Thursday, February 12, 2026 9:11 AM
> To: lr at pcorp.us
> Cc: Paul Ramsey <pramsey at cleverelephant.ca>; postgis-
> devel at lists.osgeo.org
> Subject: Re: ERROR: Could not add geog_brin_inclusion_merge to
use
> PostGIS BRIN?)
> We hit this again while/after upgrading one of our remaining
pg17+postgis3.4
> customers to pg18+postgis3.6.
> # SELECT postgis_full_version();
> postgis_full_version | POSTGIS="3.6.1 f533623" [EXTENSION] PGSQL="170"
> (procs need upgrade for use with PostgreSQL "180") GEOS="3.11.2-CAPI-
> 1.17.2" PROJ="7.1.1 NETWORK_ENABLED=OFF
> URL_ENDPOINT=https://cdn.proj.org
> USER_WRITABLE_DIRECTORY=/var/lib/pgsql/.local/share/proj
> DATABASE_PATH=/usr/proj71/share/proj/proj.db" LIBXML="2.9.1"
> LIBJSON="0.11" (core procs from "3.4.2 3.4.2" need upgrade)
> $ rpm -qa postgis\*
> postgis34_17-3.4.2-4PGDG.el7.x86_64
> postgis36_18-3.6.1-1PGDG.el7.x86_64
> # SELECT * FROM pg_catalog.pg_opclass WHERE opcname ILIKE 'brin%';
>   oid  | opcmethod |            opcname             | opcnamespace |
opcowner |
> opcfamily | opcintype | opcdefault | opckeytype
>  21756 |      3580 | brin_geometry_inclusion_ops_2d |         2200 |
10 |
> 21746 |     27847 | t          |      27830
>  21768 |      3580 | brin_geometry_inclusion_ops_3d |         2200 |
10 |
> 21764 |     27847 | f          |      27859
>  21778 |      3580 | brin_geometry_inclusion_ops_4d |         2200 |
10 |
> 21774 |     27847 | f          |      27859
> > Also, the data dir was originally initdb'd under centos (7, and
> > probably earlier versions before that), and most recently migrated to
> > debian (with the requisite reindex).
> This time, the server is still running centos7.  I've built my own RPMs
for
> pg18 and postgis, since pgdg doesn't provides RPMs for new versions on old
> OSes.
> Let me know if I can add anything else.
> On Sun, Mar 02, 2025 at 05:53:23PM -0500, lr at pcorp.us wrote:
> > Justin,
> > Thanks.  So it looks like brin was never installed in one version of
> > yours and in your second the geography brin was never installed.
> > We've had issues over the years with some BRIN installs being missing
> > or partly missing because of not catching pg_upgrade changes in
> > PostgreSQL version.
> > Anyrate I'll try to catch this situation and install BRIN if it is
> > found to be missing.
> > Thanks,
> > Regina
> > > Sent: Sunday, March 2, 2025 5:24 PM
> > > To: lr at pcorp.us
> > > postgis-devel at lists.osgeo.org
> > > Do you
> > use
> > > PostGIS BRIN?)
> > > On Sun, Mar 02, 2025 at 04:52:48PM -0500, lr at pcorp.us wrote:
> > > > I've ticketed this issue here:
> > > > https://trac.osgeo.org/postgis/ticket/5856
> > > > I'm going to try to revise the upgrade script to account for this
> > scenario.
> > > > Can you do me a favor, send me the output of this from your
> > > > problem
> > > > database:
> > > The DB where we hit the error says:
> > > ts=# SELECT * FROM pg_catalog.pg_opclass WHERE opcname ILIKE
> 'brin%';
> > opcowner |
> > >  17704 |      3580 | brin_geometry_inclusion_ops_2d |         2200 |
> > 10 |
> > > 17694 |     16419 | t          |      16454
> > >  17716 |      3580 | brin_geometry_inclusion_ops_3d |         2200 |
> > 10 |
> > > 17712 |     16419 | f          |      16458
> > >  17726 |      3580 | brin_geometry_inclusion_ops_4d |         2200 |
> > 10 |
> > > 17722 |     16419 | f          |      16458
> > > (3 rows)
> > > And the 2nd instance I mentioned which has no
> > > opcname='brin_geography_inclusion_ops' says:
> > > 'brin%';  oid
> > > | opcmethod | opcname | opcnamespace | opcowner | opcfamily |
> > > | opcintype opcdefault | opckeytype
> > > (0 rows)
> Justin Pryzby
> System Administrator
> Telsasoft
> +1-952-707-8581
