ERROR: Could not add geog_brin_inclusion_merge to brin_geography_inclusion_ops..null value in column "refobjid" (Re: Do you use PostGIS BRIN?)
Justin Pryzby pryzby at telsasoft.com
Thu Feb 12 08:05:12 PST 2026
I've hit this 2 or 3 times now on different customers.  We usually
pg_upgrade to new major versions pretty quickly after they're released,
and maybe this issue is fallout from that.
This instance started with pg14 and was pg_upgraded every year since
then.  This is the version history for postgres:
postgres=# SELECT t::date, name, setting FROM pg_settings_snap WHERE name='server_version_num' ORDER BY 1;
     t      |        name        | setting
 2021-11-12 | server_version_num | 140000
 2022-02-11 | server_version_num | 140001
 2022-05-13 | server_version_num | 140002
 2022-06-20 | server_version_num | 140003
 2022-08-12 | server_version_num | 140004
 2022-10-20 | server_version_num | 140005
 2022-11-11 | server_version_num | 150000
 2023-02-21 | server_version_num | 150001
 2023-05-11 | server_version_num | 150002
 2023-08-10 | server_version_num | 150003
 2023-09-20 | server_version_num | 150004
 2023-11-07 | server_version_num | 160000
 2024-02-06 | server_version_num | 160001
 2024-05-10 | server_version_num | 160002
 2024-08-09 | server_version_num | 160003
 2024-09-30 | server_version_num | 160004
 2024-11-12 | server_version_num | 170000
 2024-11-20 | server_version_num | 170001
 2025-02-19 | server_version_num | 170002
 2025-05-06 | server_version_num | 170004
 2025-08-20 | server_version_num | 170005
 2026-02-12 | server_version_num | 170006
 2026-02-12 | server_version_num | 180002
Here's the available version history for postgis:
$ sudo grep gis /var/log/yum.log-* /var/log/yum.log
/var/log/yum.log-20230101:Oct 20 18:08:51 Installed: postgis33_15-3.3.1-2.rhel7.x86_64
/var/log/yum.log-20230101:Oct 20 18:08:51 Installed: postgis33_15-client-3.3.1-2.rhel7.x86_64
/var/log/yum.log-20240101:Sep 20 05:43:25 Installed: postgis34_16-3.4.0-1PGDG.el7.x86_64
/var/log/yum.log-20240101:Nov 30 03:45:49 Updated: postgis34_16-3.4.1-1PGDG.el7.x86_64
/var/log/yum.log-20250101:Aug 09 05:42:49 Updated: postgis34_16-3.4.2-1PGDG.el7.x86_64
/var/log/yum.log-20250101:Sep 30 04:57:32 Installed: postgis34_17-3.4.2-4PGDG.el7.x86_64
/var/log/yum.log:Feb 10 05:20:59 Installed: postgis36_18-3.6.1-1PGDG.el7.x86_64
This package is still installed, and might indicate the oldest postgis
that it started with:
postgis31_14-docs-3.1.4-1.rhel7.x86_64
On Thu, Feb 12, 2026 at 10:09:31AM -0500, Regina Obe wrote:
> Justin,
> Remind me do you always have this issue when upgrading older customers
> (those who have been running PostGIS since at least PostgreSQL 9.3) or only
> with some customers?
> > -----Original Message-----
> > From: Justin Pryzby <pryzby at telsasoft.com>
> > Sent: Thursday, February 12, 2026 9:11 AM
> > To: lr at pcorp.us
> > Cc: Paul Ramsey <pramsey at cleverelephant.ca>; postgis-
> > devel at lists.osgeo.org
> > Subject: Re: ERROR: Could not add geog_brin_inclusion_merge to
> use
> > PostGIS BRIN?)
> > We hit this again while/after upgrading one of our remaining
> pg17+postgis3.4
> > customers to pg18+postgis3.6.
> > # SELECT postgis_full_version();
> > postgis_full_version | POSTGIS="3.6.1 f533623" [EXTENSION] PGSQL="170"
> > (procs need upgrade for use with PostgreSQL "180") GEOS="3.11.2-CAPI-
> > 1.17.2" PROJ="7.1.1 NETWORK_ENABLED=OFF
> > URL_ENDPOINT=https://cdn.proj.org
> > USER_WRITABLE_DIRECTORY=/var/lib/pgsql/.local/share/proj
> > DATABASE_PATH=/usr/proj71/share/proj/proj.db" LIBXML="2.9.1"
> > LIBJSON="0.11" (core procs from "3.4.2 3.4.2" need upgrade)
> > $ rpm -qa postgis\*
> > # SELECT * FROM pg_catalog.pg_opclass WHERE opcname ILIKE 'brin%';
> >   oid  | opcmethod |            opcname             | opcnamespace |
> opcowner |
> > opcfamily | opcintype | opcdefault | opckeytype
> >  21756 |      3580 | brin_geometry_inclusion_ops_2d |         2200 |
> 10 |
> > 21746 |     27847 | t          |      27830
> >  21768 |      3580 | brin_geometry_inclusion_ops_3d |         2200 |
> 10 |
> > 21764 |     27847 | f          |      27859
> >  21778 |      3580 | brin_geometry_inclusion_ops_4d |         2200 |
> 10 |
> > 21774 |     27847 | f          |      27859
> > > Also, the data dir was originally initdb'd under centos (7, and
> > > probably earlier versions before that), and most recently migrated to
> > > debian (with the requisite reindex).
> > This time, the server is still running centos7.  I've built my own RPMs
> for
> > pg18 and postgis, since pgdg doesn't provides RPMs for new versions on old
> > OSes.
> > Let me know if I can add anything else.
> > On Sun, Mar 02, 2025 at 05:53:23PM -0500, lr at pcorp.us wrote:
> > > Justin,
> > > Thanks.  So it looks like brin was never installed in one version of
> > > yours and in your second the geography brin was never installed.
> > > We've had issues over the years with some BRIN installs being missing
> > > or partly missing because of not catching pg_upgrade changes in
> > > PostgreSQL version.
> > > Anyrate I'll try to catch this situation and install BRIN if it is
> > > found to be missing.
> > > Thanks,
> > > Regina
> > > > Sent: Sunday, March 2, 2025 5:24 PM
> > > > To: lr at pcorp.us
> > > > postgis-devel at lists.osgeo.org
> > > > Do you
> > > use
> > > > PostGIS BRIN?)
> > > > On Sun, Mar 02, 2025 at 04:52:48PM -0500, lr at pcorp.us wrote:
> > > > > I've ticketed this issue here:
> > > > > https://trac.osgeo.org/postgis/ticket/5856
> > > > > I'm going to try to revise the upgrade script to account for this
> > > scenario.
> > > > > Can you do me a favor, send me the output of this from your
> > > > > problem
> > > > > database:
> > > > The DB where we hit the error says:
> > > > ts=# SELECT * FROM pg_catalog.pg_opclass WHERE opcname ILIKE
> > 'brin%';
> > > opcowner |
> > > >  17704 |      3580 | brin_geometry_inclusion_ops_2d |         2200 |
> > > 10 |
> > > > 17694 |     16419 | t          |      16454
> > > >  17716 |      3580 | brin_geometry_inclusion_ops_3d |         2200 |
> > > 10 |
> > > > 17712 |     16419 | f          |      16458
> > > >  17726 |      3580 | brin_geometry_inclusion_ops_4d |         2200 |
> > > 10 |
> > > > 17722 |     16419 | f          |      16458
> > > > (3 rows)
> > > > And the 2nd instance I mentioned which has no
> > > > opcname='brin_geography_inclusion_ops' says:
> > > > 'brin%';  oid
> > > > | opcmethod | opcname | opcnamespace | opcowner | opcfamily |
> > > > | opcintype opcdefault | opckeytype
> > > > (0 rows)
Justin Pryzby
System Administrator
Telsasoft
+1-952-707-8581
