regression failures with latest pre-releases
Tobias Bussmann t.bussmann at gmx.net
Wed Jul 15 10:14:29 PDT 2026
after building the latest releases on macOS Tahoe with
* PostGIS 3.7.0alpha1
* PostgresQL 19beta2
* GEOS 3.15.0beta1
* SFCGAL 2.3.0
* GDAL 3.13.1
* PROJ 9.8.1
I'm seeing quite a lot regression failures in installcheck:
* 2 in core: 21 fixedoverlay_expected and 125 wrapx_expected where a LINESTRING instead of an expected MULTILINESTRING is returned
* 8 in topography (215, 254, 260, 263, 264, 265,273, 280) with different Spatial exceptions
The test suites of GEOS and PROJ are all green, if that matters.
Are these expected at that stage in development or what way of reporting would be preferred? There is likely a common root cause of these.
TIA
Tobias
