regression failures with latest pre-releases
Regina Obe
lr at pcorp.us
Wed Jul 15 23:40:05 PDT 2026
Thanks for testing 😊
> -----Original Message-----
> From: Tobias Bussmann <t.bussmann at gmx.net>
> Sent: Wednesday, July 15, 2026 5:42 PM
> To: postgis-devel at lists.osgeo.org
> Subject: Re: regression failures with latest pre-releases
> Thanks for the quick reply!
> > Am 15.07.2026 um 20:56 schrieb Regina Obe <lr at pcorp.us>:
> > I recall there were some last minute changes that Paul had to make to
> > address GEOS regressions. So these missed the alpha cut.
> ah, that could explain it. I now found the more recent commits addressing the
> regression tests.
> > Any chance you can check the latest master tar ball
> > https://postgis.net/stuff/postgis-3.7.0dev.tar.gz
> > and see if it is okay there.
> Thanks - I can confirm the regression tests are all passing when building the
> master tar ball against the same environment.
> Will rebundle once beta1 is released.
> Tobias
