regression failures with latest pre-releases
Tobias Bussmann t.bussmann at gmx.net
Wed Jul 15 14:41:32 PDT 2026
Thanks for the quick reply!
> Am 15.07.2026 um 20:56 schrieb Regina Obe <lr at pcorp.us>:
> I recall there were some last minute changes that Paul had to make to
> address GEOS regressions.  So these missed the alpha cut.
ah, that could explain it. I now found the more recent commits addressing the regression tests.
> Any chance you can check the latest master tar ball
> https://postgis.net/stuff/postgis-3.7.0dev.tar.gz
> and see if it is okay there.
Thanks - I can confirm the regression tests are all passing when building the master tar ball against the same environment.
Will rebundle once beta1 is released.
Tobias
