WKT2 in PostGIS
Regina Obe
lr at pcorp.us
Wed Sep 9 09:18:22 PDT 2026
I thought you or somebody else was against that.
My only issue with that is at this point, it’s guaranteed each row falls into an 8kb chunk. Making that text would make it unpredictable and it’s questionable the gain we get from that.
This would only be useful for users who define their own custom projections correct and even then given those are few and far between and they probably need it more than for PostGIS, is a postgis really the best place t have this defined?
Sent: Wednesday, September 9, 2026 11:49 AM
To: Regina Obe <lr at pcorp.us>
Cc: Javier Jimenez Shaw <j1 at jimenezshaw.com>; PostGIS Development Discussion <postgis-devel at lists.osgeo.org>
Subject: Re: WKT2 in PostGIS
Why wouldn’t we just change those column definitions from varchar(N) to text?
On Sep 9, 2026, at 8:47 AM, Regina Obe <lr at pcorp.us <mailto:lr at pcorp.us> > wrote:
Javier,
We’ve been hesitant to touch this table to increase it. I know someone else requested this.
Our feeling is the proj.db should be the authoritative source for most of these.
I there a reason you wouldn’t add this to proj directly? The issue with putting it in postgis spatial_ref_sys is if you use your system beyond postgis
You’d have to duplicate the entry anyway.
But I am and I think others were concerned for many users especially those who don’t need these defs elsewhere, it’s easier to edit postgis.spatial_ref_sys,
PostGIS for since I think 3.0 has delegated most stuff to the proj.db table and just uses spatial_ref_sys auth_srid to look up the record in proj.db and largely ignores what is in srtext/proj4text columns.
I have to check the auth_name. I think we used to ignore what was in auth_name and assumed any auth_srid matched up with auth_name = epsg, but that I think changed somewhere across the line.
Paul,
If per chance you have remember or have the energy to chime in on this, that would be much appreciated.
Thanks,
Regina
From: Javier Jimenez Shaw <j1 at jimenezshaw.com <mailto:j1 at jimenezshaw.com> >
Sent: Wednesday, September 9, 2026 7:09 AM
To: postgis-devel at lists.osgeo.org <mailto:postgis-devel at lists.osgeo.org>
Subject: WKT2 in PostGIS
Hi
In the new PROJ release 9.9.0 that will be released soon, the latest version of EPSG is included.
All European realizations are included in the WKT2 of any CRS using the ETRS89 datum ensemble.
This is an example of EPSG:25830, with 4264 chars.
https://epsg.org/crs/wkt/id/25830
If you format it a bit nicely it goes up to 4874. And this is just an example.
I know that this one can be expressed just with the code. However some people (including me) need to define a CRS that is not defined in EPSG. For that we are using WKT2.
I realized today that in PostGIS the table containing the CRS has fields limited to 2048 chars, in particular "srtext".
https://postgis.net/docs/using_postgis_dbmanagement.html#spatial_ref_sys_table
CREATE TABLE spatial_ref_sys (
srid INTEGER NOT NULL PRIMARY KEY,
auth_name VARCHAR(256),
auth_srid INTEGER,
srtext VARCHAR(2048),
proj4text VARCHAR(2048)
If I have to define a CRS with WKT2 because I need some features only available in WKT2, it may not work in PostGIS. Am I right?
Thank you.
Javier.
PS this was first asked in https://lists.osgeo.org/pipermail/proj/2026-September/012183.html
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20260909/816e1252/attachment.htm>
