[postgis-tickets] [PostGIS] #2143: [raster] Width and Height column of raster_columns view may need changing
PostGIS trac at osgeo.org
Sat Dec 8 08:52:56 PST 2012
 Reporter:  dustymugs    |       Owner:  dustymugs
     Type:  enhancement  |      Status:  new
 Priority:  medium       |   Milestone:  PostGIS 2.1.0
Component:  raster       |     Version:  trunk
 Keywords:               |
 With tiles no longer being padded, right and bottom edge tiles of a
 coverage may be of different width and/or height.  The constraints
 (blocksize x and blocksize y) themselves need to be changed to constrain
 as a set (width AND height = X AND Y).
 Constraint testing would be something like the following, just in a
 function:
 SELECT
         dim
 FROM (
 SELECT ROW(4,4) AS dim
 UNION ALL
 SELECT ROW(2,4) AS dim
 UNION ALL
 SELECT ROW(4,2) AS dim
 UNION ALL
 SELECT ROW(2,2) AS dim
 ) foo
 INTERSECT
 SELECT ROW(2,3) AS dim
 So what should be the value(s) in the width/height columns of
 raster_columns?  The "desired" tile size (the one specified with -t in
 raster2psql or tilewidth/tileheight in ST_Tile()), which would be a
 singular value.  Or should the columns be an array of the permitted widths
 or heights?  Or is having two seperate columns no longer appropriate and
 there should just be one column (say "tile_size") with an array of sets
 (each set indicating a width/height).
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2143>
