[postgis-tickets] [PostGIS] #2143: [raster] Width and Height column of raster_columns view may need changing
trac at osgeo.org
Sat Dec 8 09:18:01 PST 2012
Reporter: dustymugs | Owner: dustymugs
Type: enhancement | Status: new
Priority: medium | Milestone: PostGIS 2.1.0
Component: raster | Version: trunk
Keywords: |
Comment(by pracine):
By "Width" and "Height" I guess you mean "blocksize_x" and "blocksize_y"?
They should be the identical x and y size of the blocks, except the right-
most and bottom tiles. There is no need to know about the size of the
smaller tiles in the metadata.
So the check should be the same but so not take the right-most and bottom
tiles in the computation.
I think the best way to test for the right most and bottom tiles is to
build a dummy empty raster with the extent with a scale_x = blocksize_x
and scale_y = -blocksize_y and to check if the upperleft corner of the
tiles are equal to the upperleft corner of the (width - 1) and (height -
1) pixels of the dummy raster.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2143#comment:1>
