[postgis-tickets] [PostGIS] #2143: [raster] Width and Height column of raster_columns view may need changing
PostGIS trac at osgeo.org
Sat Dec 8 10:32:20 PST 2012
 Reporter:  dustymugs    |       Owner:  dustymugs
     Type:  enhancement  |      Status:  new
 Priority:  medium       |   Milestone:  PostGIS 2.1.0
Component:  raster       |     Version:  trunk
 Keywords:               |
Comment(by pracine):
 A tentative algo to apply the width constraint:
 1) Compute the extent of the whole coverage (fast enough)
 2) Get the width and the height of the tile intersecting the upper left
 corner of the extent (fast if there is an index. There should be one)
 3) Rasterize the extent with the width and the height obtained in 2)
 (fast)
 4) Set the constraint like this:
 ALTER TABLE schemaname.tablename
 ADD CONSTRAINT enforce_width_tablename
 CHECK (st_width(rast) = width AND (st_upperleft(x) !=
 st_rastertoworldcoordx(rasterizedextent, st_width(rasterrisedextent) - 1,
 1)))
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2143#comment:2>
