[postgis-tickets] [PostGIS] #2143: [raster] Width and Height column of raster_columns view may need changing
PostGIS trac at osgeo.org
Sat Dec 8 12:52:07 PST 2012
 Reporter:  dustymugs    |       Owner:  dustymugs
     Type:  enhancement  |      Status:  new
 Priority:  medium       |   Milestone:  PostGIS 2.1.0
Component:  raster       |     Version:  trunk
 Keywords:               |
Comment(by dustymugs):
 Your algo is flawed in step 2.  There is no way to access an index.  As
 per PostgreSQL's docs:
 [http://www.postgresql.org/docs/9.0/static/sql-createtable.html]
   Currently, CHECK expressions cannot contain subqueries nor refer to
 variables other than columns of the current row.
 Additionally, any access to an index requires knowing the names of the
 table and column you're dealing with.  You won't know that in a CHECK
 constraint.  Sure, you could hard code the names in... but that fails you
 the moment you need to change the table or column name.
 There also is NO way to determine what value to put into the
 raster_columns view from that algo.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2143#comment:3>
