[postgis-tickets] [PostGIS] #1959: Upgrading with extensions getting a row is too big
trac at osgeo.org
Mon Dec 17 08:20:57 PST 2012
Reporter: robe | Owner: robe
Type: defect | Status: new
Priority: blocker | Milestone: PostGIS 2.1.0
Component: build/upgrade/install | Version: trunk
Keywords: |
Comment(by robe):
As suggested by Andres. I did a back trace against my mingw64 windows
32-bit (this one is running 9.2.1 haven't upgraded it to 9.2.2 yet)
install exhibits same issue as my EDB install. EDB bt provided no useful
info:
but mingw bt provided this. Which I'm not sure is useful or not.
# SELECT pg_backend_pid();
> 5416
$ gdb -p 5416
(gdb) b hio.c:24
(gdb) c
# ALTER EXTENSION postgis UPDATE TO "2.1.0SVN";
(gdb) bt full
Yields:
Breakpoint 1 at 0x429df0: file hio.c, line 24.
(gdb) c
Continuing.
[Switching to Thread 5416.0x174]
Breakpoint 1, RelationPutHeapTuple (relation=0x1d749d8, buffer=1640,
tuple=0x1da9500) at hio.c:38
38 {
(gdb) bt full
#0 RelationPutHeapTuple (relation=0x1d749d8, buffer=1640,
tuple=0x1da9500)
at hio.c:38
pageHeader = <optimized out>
offnum = <optimized out>
__func__ = "RelationPutHeapTuple"
#1 0x004250de in heap_update (relation=0x1d749d8, otid=0x1da9504,
newtup=0x1da9500, ctid=0x1ccef36, update_xmax=0x1ccef3c, cid=0,
crosscheck=0x0, wait=1 '\001') at heapam.c:3156
result = <optimized out>
xid = 697
hot_attrs = 0x1d9a398
lp = <optimized out>
oldtup = {t_len = 7011, t_self = {ip_blkid = {bi_hi = 0, bi_lo =
3},
ip_posid = 1}, t_tableOid = 8, t_data = 0x4962258}
heaptup = 0x1da9500
page = <optimized out>
block = 1640
buffer = <optimized out>
newbuf = 1640
vmbuffer = 0
vmbuffer_new = 0
need_toast = 0 '\000'
already_marked = <optimized out>
newtupsize = <optimized out>
pagefree = <optimized out>
have_tuple_lock = <optimized out>
iscombo = 0 '\000'
use_hot_update = 0 '\000'
all_visible_cleared = 0 '\000'
all_visible_cleared_new = 0 '\000'
__func__ = "heap_update"
#2 0x004265ad in simple_heap_update (relation=0x1d749d8, otid=0x1da9504,
tup=0x1da9500) at heapam.c:3384
update_ctid = {ip_blkid = {bi_hi = 0, bi_lo = 39130},
ip_posid = 30410}
update_xmax = 31036508
__func__ = "simple_heap_update"
#3 0x0051390d in ApplyExtensionUpdates (extensionOid=24579,
pcontrol=0x1d67530, initialVersion=0x39a0290 "2.1.0SVN",
updateVersions=0x1d99920) at extension.c:2579
control = 0x1d67580
schemaName = 0x1d9a310 "public"
schemaOid = <optimized out>
extRel = 0x1d749d8
myself = {classId = 36, objectId = 60426032, objectSubId =
60424848}
extScan = 0x1d9a160
versionName = 0x1d99740 "2.1.0SVNnext"
requiredSchemas = <optimized out>
key = {{sk_flags = 0, sk_attno = 1, sk_strategy = 3, sk_subtype =
0,
sk_collation = 100, sk_func = {fn_addr = 0x6ad070 <oideq>,
fn_oid = 184, fn_nargs = 2, fn_strict = 1 '\001',
fn_retset = 0 '\000', fn_stats = 2 '\002', fn_extra = 0x0,
fn_mcxt = 0x1d59ec0, fn_expr = 0x0}, sk_argument = 24579}}
extTup = 0x1da9500
values = {0, 0, 0, 1, 31040080, 0, 0}
requiredExtensions = <optimized out>
nulls = "\000\000\000\000\000\000"
repl = "\000\000\000\001\001\000"
lc = <optimized out>
oldVersionName = 0x39a0290 "2.1.0SVN"
lcv = 0x1d99908
__func__ = "ApplyExtensionUpdates"
#4 0x0051640e in ExecAlterExtensionStmt (stmt=0x1d50cc0) at
extension.c:2492
d_new_version = <optimized out>
versionName = 0x1d50c20 "2.1.0SVNnext"
control = 0x1d67530
extensionOid = 24579
extRel = <optimized out>
0,
sk_collation = 100, sk_func = {fn_addr = 0x6a3e30 <nameeq>,
fn_oid = 62, fn_nargs = 2, fn_strict = 1 '\001',
30739464}}
extScan = <optimized out>
extTup = <optimized out>
updateVersions = <optimized out>
datum = <optimized out>
isnull = <optimized out>
__func__ = "ExecAlterExtensionStmt"
#5 0x0065393e in PortalRunUtility (portal=0x1d9ac00,
utilityStmt=0x1d50cc0,
isTopLevel=1 '\001', dest=0x1d50ea8, completionTag=0x1ccf3a4 "")
at pquery.c:1186
active_snapshot_set = 1 '\001'
__func__ = "PortalRunUtility"
#6 0x006543dd in PortalRunMulti (portal=0x1d9ac00, isTopLevel=1 '\001',
dest=0x1d50ea8, altdest=0x1d50ea8, completionTag=0x1ccf3a4 "")
at pquery.c:1324
stmt = 0x1d50cc0
active_snapshot_set = <optimized out>
stmtlist_item = 0x1d50e70
#7 0x00655191 in PortalRun (portal=0x1d9ac00, count=2147483647,
isTopLevel=1 '\001', dest=0x1d50ea8, altdest=0x1d50ea8,
completionTag=0x1ccf3a4 "") at pquery.c:815
save_exception_stack = 0x1ccf3e4
save_context_stack = 0x0
local_sigjmp_buf = {30208536, 30209060, 31042560, 30208932,
30208364,
6639617, 30212036, 0, 1447244336, 0, 30208536, 23397311, 2,
31042560, 30208536, 4215167}
nprocessed = <optimized out>
saveTopTransactionResourceOwner = 0x1d58c60
saveTopTransactionContext = 0x349c08
saveActivePortal = 0x0
saveResourceOwner = 0x1d58c60
savePortalContext = 0x0
saveMemoryContext = 0x349c08
__func__ = "PortalRun"
#8 0x00650d66 in exec_simple_query (
query_string=0x1d509b0 "ALTER EXTENSION postgis\n UPDATE TO
\"2.1.0SVNnext\
";") at postgres.c:1052
parsetree = 0x1d50cc0
portal = 0x1d9ac00
snapshot_set = 0 '\000'
commandTag = 0x8c8b9c "ALTER EXTENSION"
completionTag = "\000ELECT
1\000ôI\001\037\000\000\000.PO\000OóI\001\060
", '\000' <repeats 11 times>,
"èóI\001«+_\001\000\000\000\000\000\000\000\000oóI
\001\000\000\000\000\000\000\000"
querytree_list = <optimized out>
plantree_list = 0x1d50e88
receiver = <optimized out>
format = 0
dest = DestRemote
parsetree_list = 0x1d50cf8
save_log_statement_stats = 0 '\000'
was_logged = <optimized out>
msec_str =
"\000\000\000\000\b\000\000\000\000\004\000\000K\000\000\000x
üw\000y=\aî\037ôI\001H`_\005"
parsetree_item = 0x1d50ce0
isTopLevel = <optimized out>
#9 PostgresMain (argc=2, argv=0x3492f8, username=0x347e10 "postgres")
at postgres.c:3968
query_string = 0x1d509b0 "ALTER EXTENSION postgis\n UPDATE TO
\"2.1.0SV
Nnext\";"
dbname = <optimized out>
firstchar = 31042560
input_message = {
data = 0x1d50190 "ALTER EXTENSION postgis\n UPDATE TO
\"2.1.0SVNnext\
";", len = 52, maxlen = 1024, cursor = 52}
local_sigjmp_buf = {30209112, 30208868, 3445496, 3440144,
30208540,
6621139, 30212036, 0, 1447244336, 0, 0, 12, 7911782, 30209112,
1502717832, 95245}
send_ready_for_query = 0 '\000'
__func__ = "PostgresMain"
#10 0x00605aca in BackendRun (port=0x1ccfca8) at postmaster.c:3619
ac = 2
secs = 409075662
usecs = 825352
i = <optimized out>
av = 0x3492f8
maxac = <optimized out>
#11 SubPostmasterMain (argc=3, argv=0x3418c0) at postmaster.c:4120
port = {sock = 4, noblock = 0 '\000', proto = 196608, laddr = {
addr = {ss_family = 23, __ss_pad1 = "\025B\000\000\000",
__ss_align = 0,
__ss_pad2 = "\000\000\000\000\000\000\000\001", '\000'
<repeats 10
3 times>}, salen = 28}, raddr = {addr = {ss_family = 23,
__ss_pad1 = "x\025\000\000\000", __ss_align = 0,
<repeats 10
3 times>}, salen = 28}, remote_host = 0x1cf2c98 "::1",
remote_hostname = 0x0, remote_hostname_resolv = 0,
remote_port = 0x1cf2c88 "55061", canAcceptConnections = CAC_OK,
database_name = 0x347dd8 "testpostgis21",
user_name = 0x347e10 "postgres", cmdline_options = 0x0,
guc_options = 0x348328, hba = 0x1d46568, md5Salt = "7§ëF",
SessionStartTime = 409075662825352, default_keepalives_idle = 0,
default_keepalives_interval = 0, default_keepalives_count = 0,
keepalives_idle = 0, keepalives_interval = 0, keepalives_count =
0,
gss = 0x1cf2c58}
__func__ = "SubPostmasterMain"
#12 0x00597680 in main (argc=7015, argv=0x3418c0) at main.c:176
No locals.
(gdb)
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1959#comment:6>
