[postgis-tickets] [PostGIS] #1959: Upgrading with extensions getting a row is too big
trac at osgeo.org
Mon Dec 17 08:54:33 PST 2012
Reporter: robe | Owner: robe
Type: defect | Status: new
Priority: blocker | Milestone: PostGIS 2.1.0
Component: build/upgrade/install | Version: trunk
Keywords: |
Comment(by robe):
I think Tom might have hit the nail on head.
http://archives.postgresql.org/pgsql-bugs/2012-12/msg00159.php
"Hm ... pg_extension does not have a TOAST table. Could the extconfig
and extcondition fields be getting bloated unreasonably? If I
understand the scenario here, this would require (1) the extension
contains a configuration table (probably one with a filter condition)
and (2) for some reason the repeated updates are adding, not replacing,
entries for the table in these columns.
If that's the story it would be easy to verify by watching the
extension's pg_extension entry as you repeatedly upgrade it."
It's my spatial ref condition that is probably causing this. The
extcondition array is increasing 1 each time I run the upgrade.
CREATE EXTENSION postgis;
select array_upper(extcondition,1) from pg_extension where extname =
'postgis';
-- 1
ALTER EXTENSION postgis UPDATE TO "2.1.0SVNnext";
'postgis';
-- 2
ALTER EXTENSION postgis UPDATE TO "2.1.0SVN";
'postgis';
-- 3
ERROR: row is too big: size 9272, maximum size 8160
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1959#comment:7>
