[postgis-tickets] [PostGIS] #1959: Upgrading with extensions getting a row is too big
trac at osgeo.org
Mon Dec 17 21:15:43 PST 2012
Reporter: robe | Owner: robe
Type: defect | Status: new
Priority: blocker | Milestone: PostGIS 2.0.3
Component: build/upgrade/install | Version: trunk
Keywords: |
Changes (by robe):
* milestone: PostGIS 2.1.0 => PostGIS 2.0.3
Comment:
Okay going to consider this fixed at r10852 for postgis 2.1.0.
I still need to make the same change for postgis 2.0 branch.
I was able to make a fake_postgis extension with nothing but the suspect
pieces.
They are discussing the issue here: http://archives.postgresql.org/pgsql-
bugs/2012-12/msg00166.php
The fatal mistake I made is that I thought the
spatial_ref_sys WHERE condition I put in:
SELECT pg_catalog.pg_extension_config_dump('spatial_ref_sys', 'WHERE NOT
(srid BETWEEN ..')
Needed to prevent spatial_ref_sys records we package from being backed up
and thus failing on reinstall, would overwrite the original
spatial_ref_sys config_dump entry. Instead it just adds to it and after 3
upgrades (the array exceeds the limit of pg_extension space since
pg_extension doesn't have a companion TOAST table to hold the extra load).
I'll upgrade my production system running 2.1.0SVN and if that looks good
I'll backport to 2.0.3 and test by upgrading one of my 2.0 installs.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1959#comment:8>
