[postgis-tickets] [PostGIS] #2153: No rule to make target .../tiger_loader_2011.sql needed by sql_bits/tiger_geocoder.sql.in
trac at osgeo.org
Mon Dec 17 23:38:58 PST 2012
Reporter: strk | Owner: robe
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.1.0
Component: build/upgrade/install | Version: trunk
Keywords: |
make[2]: *** No rule to make target
`../../extras/tiger_geocoder/tiger_2011/tables/tiger_loader_2011.sql',
needed by `sql_bits/tiger_geocoder.sql.in'. Stop.
The error is transient (ie: doesn't stop the build) but it is suspicious.
It shouldn't happen, should it ?
Sounds EXTENTION-ish
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2153>
