[postgis-tickets] [PostGIS] #2160: [raster] regress failure rt_mapalgebra_expr windows vc builds
PostGIS trac at osgeo.org
Sun Dec 30 06:24:14 PST 2012
 Reporter:  robe     |       Owner:  dustymugs
     Type:  defect   |      Status:  new
 Priority:  blocker  |   Milestone:  PostGIS 2.1.0
Component:  raster   |     Version:  trunk
 Keywords:           |
 In troubleshooting the other #2158 I came across another unpleasant
 result.  It seems my 9.2 32-bit EDB (regress against EDB build) is failing
 on the rt_mapalgebra_expr raster test.
 I've attached results.  The mingw tested one is fine.  I'm going thru and
 checking my other EDB builds.  As I recall with the 64-bit one, I have
 some crashes with KML/GML but I think the raster tests always passed.
 the test_58_diff has output like this:
 99.OBT: |1|FIRST||||||||||||||
 99.EXP: |1|FIRST|0.000|0.000|0|0|1.000|-1.000|0.000|0.000|0|0||||
 101.OBT: |3|FIRST||||||||||||||
 101.EXP: |3|FIRST|0.000|0.000|0|0|1.000|-1.000|0.000|0.000|0|0||||
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2160>
