[postgis-tickets] [PostGIS] #2160: [raster] regress failure rt_mapalgebra_expr windows vc builds
PostGIS trac at osgeo.org
Sun Dec 30 06:27:02 PST 2012
 Reporter:  robe     |       Owner:  dustymugs
     Type:  defect   |      Status:  new
 Priority:  blocker  |   Milestone:  PostGIS 2.1.0
Component:  raster   |     Version:  trunk
 Keywords:           |
Comment(by robe):
 forgot these details:
 PostgreSQL 9.2.1, compiled by Visual C++ build 1600, 32-bit
  - 2012-12-30 10:46:41
   GEOS: 3.4.0dev-CAPI-1.8.0 r0
   PROJ: Rel. 4.8.0, 6 March 2012
   GDAL: GDAL 1.9.2, released 2012/10/08
 Running tests
  check_gdal .. ok
  check_raster_columns .. ok
  check_raster_overviews .. ok
  rt_io .. ok
  rt_bytea .. ok
  box3d .. ok
  rt_addband .. ok
  rt_band .. ok
  rt_tile .. ok
  rt_dimensions .. ok
  rt_scale .. ok
  rt_pixelsize .. ok
  rt_upperleft .. ok
  rt_rotation .. ok
  rt_georeference .. ok
  rt_set_properties .. ok
  rt_isempty .. ok
  rt_hasnoband .. ok
  rt_metadata .. ok
  rt_rastertoworldcoord .. ok
  rt_worldtorastercoord .. ok
  rt_band_properties .. ok
  rt_set_band_properties .. ok
  rt_setvalues_array .. ok
  rt_summarystats .. ok
  rt_count .. ok
  rt_histogram .. ok
  rt_quantile .. ok
  rt_valuecount .. ok
  rt_valuepercent .. ok
  rt_bandmetadata .. ok
  rt_pixelvalue .. ok
  rt_neighborhood .. ok
  rt_nearestvalue .. ok
  rt_pixelofvalue .. ok
  rt_pixelaspolygons .. ok
  rt_pixelaspoints .. ok
  rt_pixelascentroids .. ok
  rt_polygon .. ok
  rt_utility .. ok
  rt_asgdalraster .. ok
  rt_astiff .. ok
  rt_asjpeg .. ok
  rt_aspng .. ok
  rt_reclass .. ok
  rt_gdalwarp .. ok
  rt_asraster .. ok
  rt_dumpvalues .. ok
  rt_mapalgebraexpr .. ok
  rt_mapalgebrafct .. ok
  rt_mapalgebraexpr_2raster .. ok
  rt_mapalgebrafct_2raster .. ok
  rt_mapalgebrafctngb .. ok
  rt_mapalgebrafctngb_userfunc .. ok
  rt_intersection .. ok
  rt_clip .. ok
  rt_mapalgebra .. ok
  rt_mapalgebra_expr .. failed (diff expected obtained: /tmp/pgis_reg/tes
 f)
  rt_union .. ok
  rt_invdistweight4ma .. ok
  rt_4ma .. ok
  rt_setvalues_geomval .. ok
  rt_elevation_functions .. ok
  rt_gist_relationships .. ok
  rt_intersects .. ok
  rt_samealignment .. ok
  rt_geos_relationships .. ok
  rt_iscoveragetile .. ok
  bug_test_car5 .. ok
  tickets .. ok
  loader/Basic .... ok
  loader/BasicCopy .... ok
  loader/Tiled10x10 .... ok
  loader/Tiled10x10Copy .... ok
  loader/Tiled8x8 .... ok
 )uninstall .. ok (4061
 Run tests: 76
 Failed: 1
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2160#comment:1>
