[postgis-tickets] [PostGIS] #2161: Documentation tooltips are very irritating
trac at osgeo.org
Mon Dec 31 14:53:36 PST 2012
Reporter: autarch | Owner: robe
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.0.3
Component: documentation | Version: 2.0.x
Keywords: |
Comment(by robe):
okeedoke just had Debbie rebuild the 1.4.2 docs
http://postgis.net/docs/manual-1.4/
and it has tooltips, but the old one doesn't.
http://postgis.org/documentation/manual-1.4/
I'm not sure if the old was built by Hudson or Paul when he was releasing.
I'm not quite sure why they are different aside from revision number
thing.
strk, pramsey -- you're setup locally to build docs right? Can you check
and see if yours generates mouseovers on links?
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2161#comment:2>
