[postgis-tickets] [PostGIS] #2396: liblwgeom CUnit tests fail on big-endian architectures.
trac at osgeo.org
Sun Aug 4 08:30:43 PDT 2013
Reporter: mnencia | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.0.4
Component: postgis | Version: 2.0.x
Keywords: |
Comment(by mnencia):
I'm afraid it's not a matter of an unit test issue. I ran the regression
tests on Sparc and I obtained a couple of failures.
I attach them here as I don't know if the issues are related.
--- regress_expected 2012-02-27 22:08:12.000000000 +0000
+++ /tmp/pgis_reg/test_24_out 2013-08-01 14:44:21.000000000 +0000
@@ -154,7 +154,7 @@
148|LINESTRING(0 0,5 0,10 0)
149|GEOMETRYCOLLECTION EMPTY
150|SRID=6;GEOMETRYCOLLECTION(POLYGON((0 0,1 0,1 1,0 1,0 0)))
-151|0103000020E61000000100000005000000000000000000000000000000000000000000000000000000000000000000F03F000000000000F03F000000000000F03F000000000000F03F000000000000000000000000000000000000000000000000
+151|0020000003000010E600000001000000050000000000000000000000000000000000000000000000003FF00000000000003FF00000000000003FF00000000000003FF0000000000000000000000000000000000000000000000000000000000000
152|4326
152.1|t
152.2|4326
@@ -167,7 +167,7 @@
159|MULTIPOLYGON EMPTY
160|MULTIPOINT(1 1)
161|MULTILINESTRING((0 0,1 1),(2 2,3 3))
-162|010200000003000000F771D98DE33826C00000000000004440F771D98DE33826C000000000008051400000000000805140F771D98DE33826C0
+162|000000000200000003C02638E38DD971F74044000000000000C02638E38DD971F740518000000000004051800000000000C02638E38DD971F7
163|POLYGON((0 0 0,1 0 0,1 1 0,0 1 0,0 0 0))
164|POLYGON((0 0 0,1 0 0,1 1 0,0 1 0,0 0 1))
ERROR: geometry contains non-closed rings
--- empty_expected 2012-02-27 22:08:12.000000000 +0000
+++ /tmp/pgis_reg/test_35_out 2013-08-01 14:44:32.000000000 +0000
@@ -23,13 +23,13 @@
T3.16|
T3.17|
T3.18|
-ST_Buffer(empty, tolerance) == empty|010300000000000000
-ST_Union(geometry, empty) ==
geometry|0103000000010000000400000000000000000000000000000000000000000000000000244000000000000000000000000000001440000000000000144000000000000000000000000000000000
-ST_Union(empty, empty) == empty|010300000000000000
-ST_Intersection(geometry, empty) == geometry|010300000000000000
-ST_Intersection(empty, empty) == empty|010300000000000000
-ST_Difference(geometry, empty) ==
-ST_Difference(empty, geometry) == empty|010300000000000000
+ST_Buffer(empty, tolerance) == empty|000000000300000000
+ST_Union(geometry, empty) ==
geometry|0000000003000000010000000400000000000000000000000000000000402400000000000000000000000000004014000000000000401400000000000000000000000000000000000000000000
+ST_Union(empty, empty) == empty|000000000300000000
+ST_Intersection(geometry, empty) == geometry|000000000300000000
+ST_Intersection(empty, empty) == empty|000000000300000000
+ST_Difference(geometry, empty) ==
+ST_Difference(empty, geometry) == empty|000000000300000000
ST_Distance(geometry, empty) == NULL|
ST_DWithin(geometry, empty, tolerance) == FALSE|f
ST_Within(geometry, empty) == FALSE|f
@@ -47,8 +47,8 @@
ST_NRings(empty) == 0|0
ST_NumPoints(empty) == 0|0
ST_NPoints(empty) == 0|0
-ST_GeometryN(empty, n) == empty|010300000000000000
-ST_ExteriorRing(empty) == empty|010200000000000000
+ST_GeometryN(empty, n) == empty|000000000300000000
+ST_ExteriorRing(empty) == empty|000000000200000000
ST_InteriorRingN(empty, n) == NULL|
ST_Area(empty) == 0|0
ST_Length(empty) == 0|0
--- sql-mm-compoundcurve_expected 2012-02-27 22:08:12.000000000
+0000
+++ /tmp/pgis_reg/test_42_out 2013-08-01 14:44:37.000000000 +0000
@@ -66,11 +66,11 @@
public.compoundcurve.the_geom_3dz effectively removed.
public.compoundcurve.the_geom_3dm effectively removed.
public.compoundcurve.the_geom_2d effectively removed.
-valid wkt compound curve
1|0109000000020000000102000000030000009FE5797057376340E09398B1B2373BC05AAE0A165F0963409F6760A2493D3DC0DB6286DFB057634082D8A1B32F843EC0010200000004000000DB6286DFB057634082D8A1B32F843EC075B4E4D0C60C634031FA5D1A371540C0D7197CED9B636340A3CB59A7630A41C050F4A72AC0FB6240974769FCE3CF41C0
2|0109000000010000000102000000060000009FE5797057376340E09398B1B2373BC05AAE0A165F0963409F6760A2493D3DC0DB6286DFB057634082D8A1B32F843EC075B4E4D0C60C634031FA5D1A371540C0D7197CED9B636340A3CB59A7630A41C050F4A72AC0FB6240974769FCE3CF41C0
3|0109000000010000000102000000030000000CE586D73CF36240BBC46888F0523BC0102E91C951E76240DF90A1BEC0F841C0F970C100FFD7624074ADE6CE86CD3BC0
4|0109000000020000000102000000030000009FE5797057376340E09398B1B2373BC05AAE0A165F0963409F6760A2493D3DC0DB6286DFB057634082D8A1B32F843EC0010800000005000000DB6286DFB057634082D8A1B32F843EC0DB6286DFB057634082D8A1B32F843EC075B4E4D0C60C634031FA5D1A371540C0D7197CED9B636340A3CB59A7630A41C050F4A72AC0FB6240974769FCE3CF41C0
5|010900000003000000010800000003000000468280E724BC6340BF4B46210B973BC0F890AEA18D8063402D9664151D483CC0EED64BB6EE726340903CA5BDA0863AC0010200000004000000EED64BB6EE726340903CA5BDA0863AC09FE5797057376340E09398B1B2373BC05AAE0A165F0963409F6760A2493D3DC0DB6286DFB057634082D8A1B32F843EC0010800000005000000DB6286DFB057634082D8A1B32F843EC0DB6286DFB057634082D8A1B32F843EC075B4E4D0C60C634031FA5D1A371540C0D7197CED9B636340A3CB59A7630A41C050F4A72AC0FB6240974769FCE3CF41C0
+valid wkt compound curve
1|000000000900000002000000000200000003406337577079E59FC03B37B2B19893E04063095F160AAE5AC03D3D49A260679F406357B0DF8662DBC03E842FB3A1D882000000000200000004406357B0DF8662DBC03E842FB3A1D88240630CC6D0E4B475C04015371A5DFA314063639BED7C19D7C0410A63A759CBA34062FBC02AA7F450C041CFE3FC694797
2|000000000900000001000000000200000006406337577079E59FC03B37B2B19893E04063095F160AAE5AC03D3D49A260679F406357B0DF8662DBC03E842FB3A1D88240630CC6D0E4B475C04015371A5DFA314063639BED7C19D7C0410A63A759CBA34062FBC02AA7F450C041CFE3FC694797
3|0000000009000000010000000002000000034062F33CD786E50CC03B52F08868C4BB4062E751C9912E10C041F8C0BEA190DF4062D7FF00C170F9C03BCD86CEE6AD74
4|000000000900000002000000000200000003406337577079E59FC03B37B2B19893E04063095F160AAE5AC03D3D49A260679F406357B0DF8662DBC03E842FB3A1D882000000000800000005406357B0DF8662DBC03E842FB3A1D882406357B0DF8662DBC03E842FB3A1D88240630CC6D0E4B475C04015371A5DFA314063639BED7C19D7C0410A63A759CBA34062FBC02AA7F450C041CFE3FC694797
5|0000000009000000030000000008000000034063BC24E7808246C03B970B21464BBF4063808DA1AE90F8C03C481D1564962D406372EEB64BD6EEC03A86A0BDA53C90000000000200000004406372EEB64BD6EEC03A86A0BDA53C90406337577079E59FC03B37B2B19893E04063095F160AAE5AC03D3D49A260679F406357B0DF8662DBC03E842FB3A1D882000000000800000005406357B0DF8662DBC03E842FB3A1D882406357B0DF8662DBC03E842FB3A1D88240630CC6D0E4B475C04015371A5DFA314063639BED7C19D7C0410A63A759CBA34062FBC02AA7F450C041CFE3FC694797
ERROR: incontinuous compound curve
ERROR: geometry must have an odd number of points
@@ -80,8 +80,8 @@
valid wkb compound curve 4|COMPOUNDCURVE((153.72942375
-27.2175704,152.29285719 -29.23940482,154.74034096
-30.51635287),CIRCULARSTRING(154.74034096 -30.51635287,154.74034096
-30.51635287,152.39926953 -32.16574411,155.11278414
-34.08116619,151.86720784 -35.62414508))
valid wkb compound curve 5|COMPOUNDCURVE(CIRCULARSTRING(157.87950492
-27.59001358,156.01728901 -28.28169378,155.59163966
-26.52589021),(155.59163966 -26.52589021,153.72942375
null response|
-minpoints issues -
pass|01090000000100000001020000000200000000000000000000000000000000000000000000000000F03F000000000000F03F
-minpoints issues -
pass|010900000001000000010800000003000000000000000000000000000000000000000000000000000000000000000000F03F000000000000F03F000000000000F03F
+minpoints issues -
pass|000000000900000001000000000200000002000000000000000000000000000000003FF00000000000003FF0000000000000
+minpoints issues -
pass|0000000009000000010000000008000000030000000000000000000000000000000000000000000000003FF00000000000003FF00000000000003FF0000000000000
ERROR: geometry requires more points
--- sql-mm-curvepoly_expected 2012-02-27 22:08:12.000000000 +0000
+++ /tmp/pgis_reg/test_43_out 2013-08-01 14:44:38.000000000 +0000
@@ -71,11 +71,11 @@
public.curvepolygon.the_geom_3dm effectively removed.
public.curvepolygon.the_geom_3dz effectively removed.
public.curvepolygon.the_geom_4d effectively removed.
-valid wkt curve polygon
1|010A00000001000000010200000007000000CCDF061AD9F3614054093E6D99093EC0AB9085DBB6DD614081540229216040C0EBD7A828C33E62409BF026782A7E41C0000000C06BB2624000000020ADB440C08E632F616EAD6240C9F7B0BF1DD33DC09011EEC0DE4362407DD6672F76323EC0CCDF061AD9F3614054093E6D99093EC0
2|010A00000002000000010200000007000000CCDF061AD9F3614054093E6D99093EC0AB9085DBB6DD614081540229216040C0EBD7A828C33E62409BF026782A7E41C0000000C06BB2624000000020ADB440C08E632F616EAD6240C9F7B0BF1DD33DC09011EEC0DE4362407DD6672F76323EC0CCDF061AD9F3614054093E6D99093EC00102000000060000006844C4FE011B6240342E2993E0423FC0D45DAF9D93066240C4A0C305D62240C000000080AC31624000000020FBBE40C0000000E0107F6240000000C0A10440C04E1C0C14624C6240BF3FB6405C793FC06844C4FE011B6240342E2993E0423FC0
3|010A00000001000000010800000007000000CCDF061AD9F3614054093E6D99093EC0AB9085DBB6DD614081540229216040C0EBD7A828C33E62409BF026782A7E41C0000000C06BB2624000000020ADB440C08E632F616EAD6240C9F7B0BF1DD33DC09011EEC0DE4362407DD6672F76323EC0CCDF061AD9F3614054093E6D99093EC0
4|010A00000002000000010800000007000000CCDF061AD9F3614054093E6D99093EC0AB9085DBB6DD614081540229216040C0EBD7A828C33E62409BF026782A7E41C0000000C06BB2624000000020ADB440C08E632F616EAD6240C9F7B0BF1DD33DC09011EEC0DE4362407DD6672F76323EC0CCDF061AD9F3614054093E6D99093EC00102000000060000006844C4FE011B6240342E2993E0423FC0D45DAF9D93066240C4A0C305D62240C000000080AC31624000000020FBBE40C0000000E0107F6240000000C0A10440C04E1C0C14624C6240BF3FB6405C793FC06844C4FE011B6240342E2993E0423FC0
5|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
+valid wkt curve polygon
1|000000000A000000010000000002000000074061F3D91A06DFCCC03E09996D3E09544061DDB6DB8590ABC04060212902548140623EC328A8D7EBC0417E2A7826F09B4062B26BC0000000C040B4AD200000004062AD6E612F638EC03DD31DBFB0F7C9406243DEC0EE1190C03E32762F67D67D4061F3D91A06DFCCC03E09996D3E0954
2|000000000A000000020000000002000000074061F3D91A06DFCCC03E09996D3E09544061DDB6DB8590ABC04060212902548140623EC328A8D7EBC0417E2A7826F09B4062B26BC0000000C040B4AD200000004062AD6E612F638EC03DD31DBFB0F7C9406243DEC0EE1190C03E32762F67D67D4061F3D91A06DFCCC03E09996D3E095400000000020000000640621B01FEC44468C03F42E093292E34406206939DAF5DD4C04022D605C3A0C4406231AC80000000C040BEFB2000000040627F10E0000000C04004A1C000000040624C62140C1C4EC03F795C40B63FBF40621B01FEC44468C03F42E093292E34
3|000000000A000000010000000008000000074061F3D91A06DFCCC03E09996D3E09544061DDB6DB8590ABC04060212902548140623EC328A8D7EBC0417E2A7826F09B4062B26BC0000000C040B4AD200000004062AD6E612F638EC03DD31DBFB0F7C9406243DEC0EE1190C03E32762F67D67D4061F3D91A06DFCCC03E09996D3E0954
4|000000000A000000020000000008000000074061F3D91A06DFCCC03E09996D3E09544061DDB6DB8590ABC04060212902548140623EC328A8D7EBC0417E2A7826F09B4062B26BC0000000C040B4AD200000004062AD6E612F638EC03DD31DBFB0F7C9406243DEC0EE1190C03E32762F67D67D4061F3D91A06DFCCC03E09996D3E095400000000020000000640621B01FEC44468C03F42E093292E34406206939DAF5DD4C04022D605C3A0C4406231AC80000000C040BEFB2000000040627F10E0000000C04004A1C000000040624C62140C1C4EC03F795C40B63FBF40621B01FEC44468C03F42E093292E34
5|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
@@ -89,7 +89,7 @@
valid ewkb curve polygon 3|CURVEPOLYGON(CIRCULARSTRING(143.620251668383
-30.0374973560768,142.928571472997 -32.751011968744,145.961323098919
-34.9856710615288,149.575653076172 -33.4115333557129,149.419724075848
-29.8246726805735,146.120941605547 -30.1971158627043,143.620251668383
-30.0374973560768))
valid ewkb curve polygon 4|CURVEPOLYGON(CIRCULARSTRING(143.620251668383
-30.0374973560768),(144.843993552527 -31.2612392402209,144.205519526017
-32.2721564488616,145.552307128906 -33.4920387268066,147.970809936523
-32.0361862182617,146.386972449926 -31.4740639157242,144.843993552527
-31.2612392402209))
valid ewkb curve polygon 5|CURVEPOLYGON((143.620251668383
-30.0374973560768),COMPOUNDCURVE(CIRCULARSTRING(144.843993552527
-31.2612392402209,144.205519526017 -32.2721564488616,145.552307128906
-33.4920387268066),(145.552307128906 -33.4920387268066,147.970809936523
-32.0361862182617),CIRCULARSTRING(147.970809936523
-31.2612392402209)))
-valid curve
6|010A0000000200000001090000000200000001080000000500000000000000000000000000000000000000000000000000004000000000000000000000000000000040000000000000F03F00000000000000400000000000000840000000000000104000000000000008400102000000040000000000000000001040000000000000084000000000000010400000000000001440000000000000F03F000000000000104000000000000000000000000000000000010800000003000000333333333333FB3F000000000000F03F666666666666F63F9A9999999999D93F333333333333FB3F000000000000F03F
+valid curve
6|000000000A00000002000000000900000002000000000800000005000000000000000000000000000000004000000000000000000000000000000040000000000000003FF0000000000000400000000000000040080000000000004010000000000000400800000000000000000000020000000440100000000000004008000000000000401000000000000040140000000000003FF00000000000004010000000000000000000000000000000000000000000000000000008000000033FFB3333333333333FF00000000000003FF66666666666663FD999999999999A3FFB3333333333333FF0000000000000
-valid curve
8|010A0000000200000001090000000200000001080000000500000000000000000000000000000000000000000000000000004000000000000000000000000000000040000000000000F03F00000000000000400000000000000840000000000000104000000000000008400102000000020000000000000000001040000000000000084000000000000000000000000000000000010800000003000000333333333333FB3F000000000000F03F666666666666F63F9A9999999999D93F333333333333FB3F000000000000F03F
+valid curve
8|000000000A00000002000000000900000002000000000800000005000000000000000000000000000000004000000000000000000000000000000040000000000000003FF0000000000000400000000000000040080000000000004010000000000000400800000000000000000000020000000240100000000000004008000000000000000000000000000000000000000000000000000008000000033FFB3333333333333FF00000000000003FF66666666666663FD999999999999A3FFB3333333333333FF0000000000000
null response|
--- tickets_expected 2012-12-19 18:28:02.000000000 +0000
+++ /tmp/pgis_reg/test_66_out 2013-08-01 14:44:50.000000000 +0000
@@ -23,7 +23,7 @@
#122|CIRCULARSTRING(220268 150415,220227 150505,220227 150406)
#124a|COMPOUNDCURVE(CIRCULARSTRING(0 0,1 1,1 0),(1 0,30
5),CIRCULARSTRING(30 5,34 56,67 89))
-#145a|0103000020E610000000000000
+#145a|0020000003000010E600000000
#145b|0
#146|0|t|GEOMETRYCOLLECTION(LINESTRING(0 0,-1 -1),MULTIPOINT(1 2,2 3))
ERROR: Invalid hex string, length (267) has to be a multiple of two!
@@ -47,7 +47,7 @@
#213|17
#234|COMPOUNDCURVE((0 0,1 1))
#241|0
-#254|010700000000000000
+#254|000000000700000000
#259|
#260|1667701
#261|0
@@ -97,7 +97,7 @@
#650|MULTIPOINT(0 0,1 1,2 2)
#667|SRID=4326;CURVEPOLYGON(CIRCULARSTRING(30 40,-49.2314112161292
32.1963871193548,30 40))
#677|1121395
-#680|01d107000000000000000024c000000000000049400000000000000040
+#680|00000007d1c02400000000000040490000000000004000000000000000
#681a|
#681b|
#681c|
@@ -105,28 +105,28 @@
#681e|
#681f|
#681g|
-#682|0103000020E610000000000000
-#683|0103000020E610000000000000
+#682|0020000003000010E600000000
+#683|0020000003000010E600000000
#684,#2109|SRID=4326;POINT EMPTY
#2109|SRID=3395;POINT EMPTY
-#685|0103000020E610000000000000
-#686|0107000020E610000000000000
+#685|0020000003000010E600000000
+#686|0020000007000010E600000000
#687|f
#689|f
#690
-010200000003000000F771D98DE33826C00000000000004440F771D98DE33826C000000000008051400000000000805140F771D98DE33826C0
-#693a|0103000060E61000000100000005000000EA95B20C71C851C02B1895D409204540000000000000F03F9CC420B072C851C0C7BAB88D062045400000000000000840B1506B9A77C851C08E75711B0D20454000000000000000C0FF21FDF675C851C0F2D24D6210204540000000000000F03FEA95B20C71C851C02B1895D4092045400000000000000000
-#693b|0103000060E61000000100000007000000EA95B20C71C851C0AA605452272045400000000000000000386744696FC851C04703780B2420454000000000000034408638D6C56DC851C04703780B2420454000000000000034C08638D6C56DC851C0E3A59BC42020454000000000000014408638D6C56DC851C08048BF7D1D20454000000000000010409CC420B072C851C04703780B242045400000000000001840EA95B20C71C851C0AA605452272045400000000000003E40
+000000000200000003C02638E38DD971F74044000000000000C02638E38DD971F740518000000000004051800000000000C02638E38DD971F7
+#693a|0060000003000010E60000000100000005C051C8710CB295EA40452009D495182B3FF0000000000000C051C872B020C49C404520068DB8BAC74008000000000000C051C8779A6B50B14045200D1B71758EC000000000000000C051C875F6FD21FF40452010624DD2F23FF0000000000000C051C8710CB295EA40452009D495182B0000000000000000
+#693b|0060000003000010E60000000100000007C051C8710CB295EA40452027525460AA0000000000000000C051C86F69446738404520240B7803474034000000000000C051C86DC5D63886404520240B780347C034000000000000C051C86DC5D6388640452020C49BA5E34014000000000000C051C86DC5D638864045201D7DBF48804010000000000000C051C872B020C49C404520240B7803474018000000000000C051C8710CB295EA40452027525460AA403E000000000000
#694
ERROR: Shell is not a line
#695
ERROR: First argument must be a LINESTRING
-#696|010F000080060000000103000080010000000500000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000F03F0000000000000000000000000000F03F000000000000F03F0000000000000000000000000000F03F0000000000000000000000000000000000000000000000000000000000000000010300008001000000050000000000000000000000000000000000000000000000000000000000000000000000000000000000F03F0000000000000000000000000000F03F000000000000F03F0000000000000000000000000000F03F0000000000000000000000000000000000000000000000000000000000000000000000000000000001030000800100000005000000000000000000000000000000000000000000000000000000000000000000F03F00000000000000000000000000000000000000000000F03F0000000000000000000000000000F03F00000000000000000000000000000000000000000000F03F00000000000000000000000000000000000000000000000001030000800100000005000000000000000000F03F000000000000F03F0000000000000000000000000000F03F000000000000F03F000000000000F03F000000000000F03F0000000000000000000000000000F03F000000000000F03F00000000000000000000000000000000000000000000F03F000000000000F03F0000000000000000010300008001000000050000000000000000000000000000000000F03F00000000000000000000000000000000000000000000F03F000000000000F03F000000000000F03F000000000000F03F000000000000F03F000000000000F03F000000000000F03F00000000000000000000000000000000000000000000F03F00000000000000000103000080010000000500000000000000000000000000000000000000000000000000F03F000000000000F03F0000000000000000000000000000F03F000000000000F03F000000000000F03F000000000000F03F0000000000000000000000000000F03F000000000000F03F00000000000000000000000000000000000000000000F03F
+#696|008000000F0000000600800000030000000100000005000000000000000000000000000000000000000000000000000000000000000000000000000000003FF000000000000000000000000000003FF00000000000003FF000000000000000000000000000003FF000000000000000000000000000000000000000000000000000000000000000000000000000000080000003000000010000000500000000000000000000000000000000000000000000000000000000000000003FF000000000000000000000000000003FF00000000000003FF000000000000000000000000000003FF000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000008000000300000001000000050000000000000000000000000000000000000000000000003FF0000000000000000000000000000000000000000000003FF000000000000000000000000000003FF0000000000000000000000000000000000000000000003FF0000000000000000000000000000000000000000000000000000000000000008000000300000001000000053FF00000000000003FF000000000000000000000000000003FF00000000000003FF00000000000003FF00000000000003FF000000000000000000000000000003FF00000000000003FF0000000000000000000000000000000000000000000003FF00000000000003FF000000000000000000000000000000080000003000000010000000500000000000000003FF0000000000000000000000000000000000000000000003FF00000000000003FF00000000000003FF00000000000003FF00000000000003FF00000000000003FF00000000000003FF0000000000000000000000000000000000000000000003FF0000000000000000000000000000000800000030000000100000005000000000000000000000000000000003FF00000000000003FF000000000000000000000000000003FF00000000000003FF00000000000003FF00000000000003FF000000000000000000000000000003FF00000000000003FF0000000000000000000000000000000000000000000003FF0000000000000
#720|MULTIPOINT(-1113194.91 4838471.4,-1113194.91 7326837.72,-1113194.91
11028513.63,556597.45 4838471.4,556597.45 7326837.72,556597.45
11028513.63,2226389.82 4838471.4,2226389.82 7326837.72,2226389.82
11028513.63,3896182.18 4838471.4,3896182.18 7326837.72,3896182.18
11028513.63,5565974.54 4838471.4,5565974.54 7326837.72,5565974.54
11028513.63)
-#723|0101000020E61000006284F068E33826C00000000000004440
-#723|0107000020E610000000000000
-#723|0101000020E61000006284F068E33826C00100000000804B40
+#723|0020000001000010E6C02638E368F084624044000000000000
+#723|0020000007000010E600000000
+#723|0020000001000010E6C02638E368F08462404B800000000001
#804|<gml:Point srsName="urn:ogc:def:crs:EPSG::4326"><gml:pos
srsDimension="2">0 0</gml:pos></gml:Point>
#845|t
#834|GEOMETRYCOLLECTION(POINT(0 0 5),LINESTRING(10 10 5,10 0 5))
@@ -182,7 +182,7 @@
#1453.2|f
#1454|t
#1414|CURVEPOLYGON Z EMPTY
-#1478|01040000200100000000000000
+#1478|00200000040000000100000000
#745|GEOMETRYCOLLECTION(POLYGON((-72 42 1,-70 43 1,-71 41 1,-72 42 1)))
#1450|POINT|POLYGON
#1482|4326
@@ -217,7 +217,7 @@
#1697.2|0
#1697.3|1024
#1734.1|1026
-#1755|01010000A0E6100000000000000040554000000000008041400000000000000000
+#1755|00A0000001000010E6405540000000000040418000000000000000000000000000
#1776|POLYGON((0 0,10 0,10 10,0 0))|POLYGON((0 0,10 0,10 10,0 0))
#1791|4.7
ERROR: ST_Segmentize: invalid max_distance 0 (must be >= 0)
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2396#comment:13>
