[postgis-tickets] [PostGIS] #2405: Debbie coughing up blood on upgrade (postgis_21_minor.sql)
trac at osgeo.org
Tue Aug 6 10:51:23 PDT 2013
Reporter: robe | Owner: nicklas
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.2.0
Component: postgis | Version: trunk
Keywords: |
Comment(by nicklas):
I suspect that this is about that I have used the "new" syntax for
creating aggregates.
[http://www.postgresql.org/docs/9.1/static/sql-createaggregate.html]
and the other PostGIS vector aggregates seems to use the old syntax.
Raster uses the new syntax though, but I do not manage to understand if
those upgrade scripts is also auto generated or or written manually.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2405#comment:5>
