[postgis-tickets] [PostGIS] #2405: Debbie coughing up blood on upgrade (postgis_21_minor.sql)
trac at osgeo.org
Wed Aug 7 06:12:20 PDT 2013
Reporter: robe | Owner: nicklas
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.2.0
Component: postgis | Version: trunk
Keywords: |
Comment(by robe):
Seems to still be failing at upgrade after you made your change.
http://debbie.postgis.net:8080/job/PostGIS_Regress/2347/console
Upgrading PostGIS in 'postgis_reg'
Upgrading core
Error encountered loading
/var/lib/jenkins/workspace/postgis/branches/2.2/regress/00-regress-
install/share/contrib/postgis/postgis_upgrade_21_minor.sql, see
/var/lib/jenkins/workspace/postgis/tmp/2_2_pg9.2w64/regress_log for
details
make[1]: *** [check] Error 9
make[1]: Leaving directory
`/var/lib/jenkins/workspace/postgis/branches/2.2/regress'
make: *** [check] Error 1
I know originally that raster did not use the upgrade perl script. I
think I had coded a sed script for it. I forget if that was changed later
or if its still using the sed script I had created.
Anyway I'll take a stab at looking at this in a bit. I suspect its
something really stupid.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2405#comment:7>
