[postgis-tickets] [PostGIS] #2407: st_linetocurve and st_curvetoline behaviour change
trac at osgeo.org
Wed Aug 7 06:17:50 PDT 2013
Reporter: mjurce | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.0.4
Component: postgis | Version: 2.0.x
Keywords: |
Comment(by strk):
Ok, here's the correct padding:
MULTILINESTRING((723097.524 117088.672,724308.441
117063.281,724342.841215729 117105.022471112,724379.248151801
117145.025724211,724417.57410072 117183.194387958,724457.726731918
117219.436510698,724499.609314188 117253.664781983,724543.120948721
117285.796742909,724588.15681218 117315.754984769,724634.608409223
117343.467335533,724682.363833886 117368.867033721,724731.308039167
117391.892889235,724781.323114189 117412.489430773,724832.288568255
117430.607039462,724884.081621122 117446.202068396,724936.577498789
117459.236947784,724989.64973409 117469.680275461,725043.17047136
117477.506892534,725097.010774456 117482.697943997,725151.040937372
117485.240924154,725205.130796712 117485.129706743,725259.150045268
117482.364559695,725312.968545938 117476.952144492,725366.456645242
117468.905500116,725419.485485661 117458.244011639,725443.148 117452.604))
The geometry still only has 26 vertices rather than the 27 obtained with
any recent version (including 1.5.9-svn). The Hausdorff distance between
the one obtained with 1.5.9 and the reported one is in the order of 1e-8
over a rough total length of 2500 units. Not a big difference.
Now, the big difference is that you _can_ covert back the 26-vertices
result (old one) using ST_LineToCurve while you get an exception when you
try to convert back the 27-vertices one.
Looking to spot the problem. I'm still interested in knowing the exact
version of postgis producing the so called "old" result.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2407#comment:6>
