[postgis-tickets] [PostGIS] #2407: st_linetocurve behaviour change (was: st_linetocurve and st_curvetoline behaviour change)
    trac at osgeo.org
    Thu Aug  8 07:05:07 PDT 2013
 Reporter:  mjurce   |       Owner:  pramsey
     Type:  defect   |      Status:  new
 Priority:  medium   |   Milestone:  PostGIS 2.0.4
Component:  postgis  |     Version:  2.0.x
 Keywords:           |
Comment(by strk):
 I couldn't find any version of PostGIS that was able to given an answer to
 this query:
 select st_linetocurve(st_curvetoline('MULTICURVE((723097.524
 117088.672,724308.441 117063.281),CIRCULARSTRING(724308.441
 117063.281,724664.096 117359.505,725443.148 117452.604))'));
 Tried from 1.5.3 up to 2.2.0, all versions raise an exception.
 But passing the result of ST_CurveToLine to an ST_LineMerge make them able
 to given an answer, and indeed 1.5 answer is half the length of 2.0
 answer. Was LineMerge the missing bit ?
 ST_LineMerge(ST_CurveToLine(g)) returns a single linestring of 26 points
 with a total length of 2479 units in all versions from 1.5 to 2.2 now, so
 maybe the problem is _only_ in the ST_LineToCurve function. The input to
 ST_LineToCurve:
 LINESTRING(723097.524 117088.672,724308.441 117063.281,724342.841215728
 117105.022471111,724379.2481518 117145.02572421,724417.574100719
 117183.194387956,724457.726731915 117219.436510696,724499.609314185
 117253.66478198,724543.120948718 117285.796742906,724588.156812175
 117315.754984765,724634.608409218 117343.467335528,724682.36383388
 117368.867033715,724731.30803916 117391.892889229,724781.323114181
 117412.489430767,724832.288568246 117430.607039456,724884.081621113
 117446.20206839,724936.57749878 117459.236947778,724989.649734079
 117469.680275453,725043.170471349 117477.506892526,725097.010774444
 117482.69794399,725151.040937359 117485.240924147,725205.130796698
 117485.129706735,725259.150045253 117482.364559687,725312.968545923
 117476.952144484,725366.456645225 117468.905500109,725419.485485643
 117458.244011632,725443.148 117452.604)
 Turning the above to a curve in 1.5 returns a 7 points curve, in 2.0 and
 2.2 returns a 28 points curve (!)
 I updated the ticket summary to only mention ST_LineToCurve
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2407#comment:14>
