[postgis-tickets] [PostGIS] #2414: extension not installing tract tables and profiles not overwritten during upgrade
trac at osgeo.org
Thu Aug 8 16:23:31 PDT 2013
upgrade
Reporter: robe | Owner: robe
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.1.0
Component: tiger geocoder | Version: 2.0.x
Keywords: |
Hmm how did I let this go thru. Just realized when testing for book that
tract table is no longer being created (or at least not when I do)
CREATE EXTENSION postgis_tiger_geocoder;
I'm also testing the sh scripts under mingw. I used to take it for
granted that I was brilliant enough to write code for a system I don't use
and the scripts would just work with spot checking orsome nice Posix user
would complain if it didn't. I've just noticed minor things so far like I
hardcoded the data schema and staging in the sh scripts where as in the
windows one it reads from the configuration.
On a side note I had intended that the package profiles
sh and windows would get overridden on upgrade, and if people really
wanted to maintain their own with their own custom settings, they would
copy or revise the name of one so it doesn't get overwritten.
e.g. I have a server called t with postres running on 5438.
I renamed the "sh" profile to "sht" which has all my custom configs in it.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/2414>
