[postgis-tickets] [PostGIS] #2407: [regression] ST_CurveToLine and ST_LineToCurve are not symmetric (was: st_linetocurve behaviour change)
trac at osgeo.org
Fri Aug 9 06:55:39 PDT 2013
Reporter: mjurce | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.0.4
Component: postgis | Version: 2.0.x
Keywords: |
Comment(by strk):
I changed the summary again because I think the real problem here is being
unable to go from curve to line and back to curve in a consistent way.
This is a regression because there are known case in which 1.5.x succeeded
in doing it.
Here's an example small test input:
CIRCULARSTRING(718006.92 114480.27, 718006.381 114478.609, 718004.78
114477.91)
Passing the above to ST_CurveToLine and then to ST_LineToCurve produces a
COMPOUNDCURVE in 1.5 and a LINESTRING (the _same_ linestring generated by
ST_CurveToLine) in 2.0.
The 1.5 final output (curve):
COMPOUNDCURVE(CIRCULARSTRING(718006.92 114480.27,718006.396201402
114478.625952602,718004.826280993 114477.909987011),(718004.826280993
114477.909987011,718004.78 114477.91))
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2407#comment:18>
