[postgis-tickets] [PostGIS] #2417: pgsql2shp doesnt see SRID
trac at osgeo.org
Fri Aug 9 22:15:42 PDT 2013
Reporter: darkblueb | Owner: pramsey
Type: defect | Status: closed
Priority: medium | Milestone: PostGIS 2.1.0
Component: postgis | Version: 2.0.x
Resolution: wontfix | Keywords: srid, pgsql2shp
Changes (by robe):
* status: reopened => closed
* resolution: => wontfix
Comment:
darkblueb,
the point is that it will cause more damage to fix than just let it go.
Your example is a small table, but imagine a huge table with mixed srids.
The routine would have to check each record.
People should not be making untyped geometry tables if they expect an
typed shapefile to come out of it is my point. I'm happy to mark this as
a documentation bug and explain the issue better but don't see the need to
fix it since it is by design.
The only exception is with an SQL query which is the case where the
routine does need to compute it.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2417#comment:4>
