[postgis-tickets] [PostGIS] #2420: ST_LineToCurve turns squares into circles
PostGIS trac at osgeo.org
Sun Aug 11 06:06:24 PDT 2013
 Reporter:  strk     |       Owner:  strk
     Type:  defect   |      Status:  assigned
 Priority:  medium   |   Milestone:  PostGIS 2.0.4
Component:  postgis  |     Version:  1.5.X
 Keywords:           |
Comment(by strk):
 The same happens with triangles, for the same reason. The below image
 shows the input to ST_LineToCurve in green and the output (segmentized
 again for display purposes) in brown.
 Note that the triangle input was itself coming from the segmentation of a
 circularstring.
 [[Image(triangle-to-circle.png)]]
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2420#comment:2>
