[postgis-tickets] [PostGIS] #2420: ST_LineToCurve turns squares into circles
PostGIS trac at osgeo.org
Mon Aug 12 00:43:36 PDT 2013
  Reporter:  strk     |       Owner:  strk
      Type:  defect   |      Status:  reopened
  Priority:  medium   |   Milestone:  PostGIS 2.0.4
 Component:  postgis  |     Version:  1.5.X
Resolution:           |    Keywords:
Changes (by strk):
  * status:  closed => reopened
  * resolution:  fixed =>
Comment:
 Paul: with this being only in 2.1 or with this also going to 2.0 ?
 By the way, see also #2423 for another case of straight lines becaming
 curves.
 I start thinking the 1.5 approach (using angles) was better, what was the
 rationale for switching to distance-from-center ?
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2420#comment:10>
