[postgis-tickets] [PostGIS] #2407: [regression] ST_CurveToLine and ST_LineToCurve are not symmetric
trac at osgeo.org
Mon Aug 12 00:51:18 PDT 2013
Reporter: mjurce | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.0.4
Component: postgis | Version: 2.0.x
Keywords: |
Comment(by strk):
We don't necessarely need to fully revert to the old behavior, but some of
the approaches should probably get back, like checking angle between arc
segments. See #2423 for a clear such case.
It would help to have a more comprehensive testsuite for curves. I've only
found 4 _disabled_ tests for ST_LineToCurve in regress/sql-mm-
circularstring.sql
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2407#comment:21>
