[postgis-tickets] [PostGIS] #2423: [REGRESSION] ST_LineToCurve gets semicircle wrong
trac at osgeo.org
Mon Aug 12 03:23:06 PDT 2013
Reporter: strk | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.0.4
Component: postgis | Version: 2.0.x
Keywords: curves |
Comment(by strk):
I've a tentative fix for this that checks angle between consecutive arc
edges. Looks promising. The only failing test is for ticket #183 but the
obtained result with the patch is actually what the reporter of #183 was
hoping for (a circularstring followed by a linestring, in a compound
curve) so I'd say it's a more correct output.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2423#comment:6>
