[postgis-tickets] [PostGIS] #2422: geography regression difference ST_DWithin
trac at osgeo.org
Mon Aug 12 15:34:33 PDT 2013
Reporter: robe | Owner: pramsey
Type: defect | Status: new
Priority: high | Milestone: PostGIS 2.1.0
Component: postgis | Version: 2.1.x
Keywords: |
Comment(by pramsey):
The answer regarding why have a dwithin code line is because the distance
code line doesn't actually use the tolerance when evaluating two trees
against one another, while the dwithin code line does. The idea is the
dwithin line can short circuit out of the evaluation when it hits
something within tolerance, while the distance calculation has to check
all possibilities to get the right distance. However, the distance code
line does take in a tolerance number, it just mostly ignores it.
What this case is showing is a failure in the tolerance-based code,
perhaps, although you also have a case that shows the tree and segment
based distance calculations coming up different.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2422#comment:17>
