[postgis-tickets] [PostGIS] #2425: Tickets regress is failing
trac at osgeo.org
Mon Aug 12 19:17:55 PDT 2013
Reporter: robe | Owner: pramsey
Type: defect | Status: new
Priority: blocker | Milestone: PostGIS 2.1.0
Component: postgis | Version: 2.0.x
Keywords: |
Both winnie and debbie are screaming:
tickets .. failed (diff expected obtained:
/var/lib/jenkins/workspace/postgis/tmp/2_1_pg9.2w64/test_70_diff)
and on same ticket.
output from debbie diff looks like this:
--- tickets_expected 2013-08-12 11:21:18.000000000 -0700
+++ /var/lib/jenkins/workspace/postgis/tmp/2_1_pg9.2w64/test_70_out
2013-08-12 11:23:34.000000000 -0700
@@ -247,5 +247,6 @@
#2415.1|MULTICURVE(COMPOUNDCURVE((0 0,10 0),CIRCULARSTRING(10 0,15 1,20
10)))
#2415.2|MULTISURFACE(CURVEPOLYGON(CIRCULARSTRING(10 0,15 1,20 0,18 5,20
10,10 10,10 0)))
#2412|LINESTRING(0 0,10 0,20 0)
+WARNING: detected write past chunk end in ExprContext 0x262dcc8
#2420|LINESTRING(0 0,10 0,10 10,0 10,0 0)
#2423|POLYGON((-10 0,-9.2388 3.82683,-7.07107 7.07107,-3.82683 9.2388,0
10,3.82683 9.2388,7.07107 7.07107,9.2388 3.82683,10 0,-10 0))
Since the PostGIS bots are angry I think I'll have to postpone release
until this is sorted out.
The offending change seems to be at:
r11771
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2425>
