[postgis-tickets] [PostGIS] #2428: Add a "perQuadrant" parameter to ST_LineToCurve
PostGIS trac at osgeo.org
Wed Aug 14 00:36:51 PDT 2013
 Reporter:  strk         |       Owner:  pramsey
     Type:  enhancement  |      Status:  new
 Priority:  medium       |   Milestone:  PostGIS 2.2.0
Component:  postgis      |     Version:  trunk
 Keywords:               |
 ST_CurveToLine has a parameter to request a number of edges per circle
 quadrant. For symmetricity the same parameter should be accepted by
 ST_LineToCurve to control the minimum number of edges per quadrant
 required to define a curve. See also #2407
 NOTE: this change affects liblwgeom interface which may be changed
 (cleaner) or augmented (only worth to retain backward compatibility).
 The relevant liblwgeom interface is:
  lwgeom_desegmentize(LWGEOM *);
  lwgeom_segmentize(LWGEOM *, uint32_t);
 My suggestion is to change lwgeom_desegmentize to also take an uint32_t
 (backward incompatible change).
 Wouldn't 2.1 be a perfect moment for this ? :)
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2428>
