[postgis-tickets] [PostGIS] #2431: Regression failure from 2.0.3-2.1.0 ST_Distance
trac at osgeo.org
Thu Aug 15 11:32:15 PDT 2013
Reporter: robe | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.1.0
Component: postgis | Version: 2.0.x
Keywords: |
Comment(by nicklas):
What has happened is that distance calculation before used the global
function to tell if a geometry is a collection, which included
polyhedralsurface. Then the polyhedralsurface was taken apart into
polygons that can be handled.
In r11219, because of added curve support to the distance calculations
Paul put a collection test only for the distance calculations, that
doesn't include polyhedralsurface.
Is that intentional?
I haven't studied the details, but if the function that takes apart
collections isn't changed I guess it is just to add polyhedralsurface in
the list on collections and it should work as before.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2431#comment:2>
