[postgis-tickets] [PostGIS] #2426: Garden Crash test failed: ST_Snap
trac at osgeo.org
Fri Aug 16 07:09:12 PDT 2013
Reporter: robe | Owner: pramsey
Type: defect | Status: new
Priority: critical | Milestone: PostGIS GEOS
Component: postgis | Version: 2.1.x
Keywords: |
Comment(by strk):
I've spotted this into the logs:
snap/LineStringSnapper.cpp:349: void
geos::operation::overlay::snap::LineStringSnapper::snapSegments(geos::geom::CoordinateList&,
const ConstVect&): Assertion `pf != 0.0' failed.
Reviewing the code actually seems to suggest there's a bug in GEOS, but
for some reason I can't reproduce it with a geos-only input !?
Can you isolate a simple offending case ?
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2426#comment:10>
