[postgis-tickets] [PostGIS] #1994: Deprecate all functions with underscore_names rather than CamelCase
trac at osgeo.org
Tue Aug 20 12:55:43 PDT 2013
Reporter: strk | Owner: pramsey
Type: task | Status: closed
Priority: medium | Milestone: PostGIS 2.1.0
Component: postgis | Version: trunk
Resolution: fixed | Keywords:
Comment(by robe):
realityexists,
I couldn't agree with you more. Can you write up a separate ticket for it
and slate to 2.1.1. I have to say I had mixed feelings about these
warnings
and when I saw the junk spewing from my tiger geocoder which I need on 2.0
dbs (and issue pgRouting was having) as well I was more leaning against
this.
Technically we CAN change this in 2.1.1 since it doesn't change the API at
all, and while not quite a bug -- I would put it high up on the ANNOYING
list.
Then we can put it back in 2.2 since 2.1 and 2.2 would then have the new
functions.
I'm suspecting we'll have a 2.1.1 out in under a month since there were
some bugs I just had to push to 2.1.1 because I couldn't find a way to
recreate and they didn't look that serious.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1994#comment:17>
