[postgis-tickets] [PostGIS] #2442: [rasters] Segfault when doing raster2pgsql
trac at osgeo.org
Wed Aug 21 21:08:19 PDT 2013
Reporter: thesteve0 | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.1.0
Component: postgis | Version: 2.0.x
Keywords: |
When trying to run raster2pgsql on Fedora 19 to process a geotiff I get a
segfault
psql (PostgreSQL) 9.2.4
GDAL 1.9.2, released 2012/10/08
The file I am using is over 100 megs so I don't think I should attach it
to the ticket.
(gdb) run -s 3309 -t 100x100 -I -M -l 4 IR_R_G.tif public.erdastest >
gdb.sql
Starting program: /usr/bin/raster2pgsql -s 3309 -t 100x100 -I -M -l 4
IR_R_G.tif public.erdastest > gdb.sql
[Thread debugging using libthread_db enabled]
Using host libthread_db library "/lib64/libthread_db.so.1".
Processing 1/1: IR_R_G.tif
Program received signal SIGSEGV, Segmentation fault.
0x0000003d7667c44d in malloc_consolidate () from /usr/lib64/libc.so.6
(gdb) bt
#0 0x0000003d7667c44d in malloc_consolidate () from /usr/lib64/libc.so.6
#1 0x0000003d7667cfd6 in _int_free () from /usr/lib64/libc.so.6
#2 0x0000003a0c418278 in gtCSVDeaccess () from
/usr/lib64/libgeotiff.so.1.2
#3 0x0000003a0c4182c9 in gtCSVDeaccess () from
#4 0x0000003a0934a8c2 in GDALDriver::~GDALDriver() ()
from /usr/lib64/libgdal.so.1
#5 0x0000003a0934a8f9 in GDALDriver::~GDALDriver() ()
#6 0x0000003a0934cac0 in GDALDriverManager::~GDALDriverManager() ()
#7 0x0000003a0934caf9 in GDALDriverManager::~GDALDriverManager() ()
#8 0x0000003a090e37ce in GDALDestroy() () from /usr/lib64/libgdal.so.1
#9 0x0000003d75e0fb6a in _dl_fini () from /lib64/ld-linux-x86-64.so.2
#10 0x0000003d766392a9 in __run_exit_handlers () from /usr/lib64/libc.so.6
#11 0x0000003d766392f5 in exit () from /usr/lib64/libc.so.6
#12 0x0000003d76621b7c in __libc_start_main () from /usr/lib64/libc.so.6
#13 0x00000000004053a5 in _start ()
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2442>
