[postgis-tickets] [PostGIS] #2444: Wrong example in asTopoJON manual
trac at osgeo.org
Thu Aug 22 06:52:07 PDT 2013
Reporter: tilt | Owner: robe
Type: enhancement | Status: new
Priority: medium | Milestone: PostGIS 2.1.1
Component: documentation | Version: 2.1.x
Keywords: astopojson |
TopoJson seems to require delta values in the coordinates instead of pure
coordinates given in the example. Additionally, the indexing in arcs is
wrong and some comma's are missing in the example.
A better output example would be:
{ "type": "Topology", "transform": { "scale": [1,1], "translate":
[0,0] }, "objects": {
"P3P4": { "type": "MultiPolygon", "arcs": [[[0]],[[1,2,3,4,5,6]]]}
}, "arcs": [
[[25,30],[6,0],[0,10],[-14,0],[0,-10],[14,0]],
[[35,14],[0,-8]],
[[35,6],[12,0]],
[[47,6],[0,8]],
[[47,14],[0,8]],
[[47,22],[-12,0]],
[[35,22],[0,-8]]
To get the deltas from the coordinates is a bit tricky. Here's a
suggestion that works but it's open for improvement:
WITH points as (
SELECT nextval('mycounter') as id, m.edge_id as groupid,
(st_dumppoints(geom)).geom
FROM edgemap m, <yourTopoTable>.edge e WHERE e.edge_id = m.edge_id
compare as (
SELECT id, groupid,
first_value(geom) OVER (PARTITION BY groupid ORDER BY id )
geom0,
(geom) geom1,
(lead(geom) OVER (PARTITION BY groupid ORDER BY id ))
geom2
FROM points
SELECT
'[[' || ST_X(geom0) || ','||ST_Y(geom0)|| '],' || string_agg('['
|| ROUND(ST_X(geom2) - ST_X(geom1)) || ',' || ROUND(ST_Y(geom2) -
ST_Y(geom1)) || ']',',') || '],' as arc
FROM compare
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2444>
