[postgis-tickets] [PostGIS] #2447: wonrg LAT LONG values loading shapefile
trac at osgeo.org
Sat Aug 24 08:28:16 PDT 2013
Reporter: strutus | Owner: mcayland
Type: defect | Status: new
Priority: blocker | Milestone: PostGIS 2.1.0
Component: loader/dumper | Version: 2.0.x
Keywords: |
Loading shapefile containing POINT geom.
For some reason, the LAT and LONG values show numbers that do no t look
right when converted as TEXT (mapping using tools also do not work):
SELECT ST_AsText(geom) from welldata
"POINT(444602.87785624 3496780.24540007)"
"POINT(444393.150243643 3498954.02641898)"
SHape file was downloaded from http://sonris-
www.dnr.state.la.us/gis/agsweb/arcgisserver/arcgisoutput/extData/shp/SABINE_wells.zip
Shape loading was performed using the following command:
shp2pgsql -I -s 6805 SABINE_wells.shp welldata > wellsdata.sql
PRJ file contains:
PROJCS["NAD_1983_UTM_Zone_15N",GEOGCS["GCS_North_American_1983",DATUM["D_North_American_1983",SPHEROID["GRS_1980",6378137.0,298.257222101]],PRIMEM["Greenwich",0.0],UNIT["Degree",0.0174532925199433]],PROJECTION["Transverse_Mercator"],PARAMETER["False_Easting",500000.0],PARAMETER["False_Northing",0.0],PARAMETER["Central_Meridian",-93.0],PARAMETER["Scale_Factor",0.9996],PARAMETER["Latitude_Of_Origin",0.0],UNIT["Meter",1.0]]
Searching in spatial reference site I found this:
http://spatialreference.org/ref/sr-org/6805/
Any hints are highly appreciated.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2447>
