[postgis-tickets] [PostGIS] #2436: Build a travis test bot
trac at osgeo.org
Sat Aug 24 15:13:15 PDT 2013
Reporter: robe | Owner: robe
Type: defect | Status: new
Priority: medium | Milestone: Management 2.0
Component: buildbots | Version: 2.0.x
Keywords: |
Comment(by robe):
Getty stepped up t the plate on this one and seems to be making progress.
See irc logs http://irclogs.geoapt.com/postgis/%23postgis.2013-08-24.log
01:12:48 Getty: btw i am at froscon tomorrow
01:12:51 Getty: dont know if someone else is
02:16:07 Getty: it works!!!
02:16:09 Getty: it still fails
02:16:15 Getty: but just 3 tests
02:16:37 Getty: there is a small failure in the repo might be a
branch 2_1 problem and fixed in the trunk already
02:16:43 Getty: but ..... the travis config works
02:16:54 Getty: runtime 6 minutes
02:17:10 Getty: testing against GEOS_VERSION 3.4.1 and 3.3.8
02:17:50 Getty: oh interesting it doesnt works at all with 3.3.8
02:18:22 Getty: there is a small "bug" that forces a
/usr/lib/libgeos_c.so.1 in the regression tests
02:18:59 Getty: oh wait runtime 3 minutes
02:19:00 Getty: not 6
14:19:49 robe2: Getty great job. Thanks a bunch.
14:20:22 robe2: Getty I don't think any of us tests on 3.3.8 so
its possible it doesn't work because of changes strk made in 3.3.9
14:20:38 robe2: I thoughh we had fixed but maybe not.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2436#comment:4>
