[postgis-tickets] [PostGIS] #2454: [raster] ST_PixelAsPolygons does not obey exclude_nodata_value=TRUE
trac at osgeo.org
Fri Aug 30 09:28:09 PDT 2013
Reporter: alfred | Owner: dustymugs
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.1.1
Component: raster | Version: 2.1.x
Keywords: |
Comment(by alfred):
I have been using this workaround for now, by checking if the value is
equal to the NODATA value.
In my case i have rasters where only small portions contain data and i am
attempting to iterate the areas that have data and set values.
The problem with that is that it increases the query time significantly by
going over all the pixels (can be thousands of those), even that i care
only about the ones that have data only.
I was hoping that now that this function is implemented in C that this
will provide boost in the speed, which it seems that it does in general,
but not for this case.
I still think that having the "exlude_nodata_value" , should NOT return
those pixels.
Having it set as false should return all the pixels and the values can
still be checked with a WHERE clause. I don't see much benefit of having
it set to NULL as in any case there needs to be a WHERE clause and the
same can checked for being equal to ST_BandNoDataValue , but may be nice
option in some cases.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2454#comment:7>
