[postgis-tickets] [PostGIS] #2454: [raster] ST_PixelAsPolygons does not obey exclude_nodata_value=TRUE
trac at osgeo.org
Fri Aug 30 09:38:06 PDT 2013
Reporter: alfred | Owner: dustymugs
Type: defect | Status: assigned
Priority: medium | Milestone: PostGIS Future
Component: raster | Version: trunk
Keywords: |
Comment(by dustymugs):
> The problem with that is that it increases the query time significantly
by going over all the pixels (can be thousands of those), even that i care
only about the ones that have data only.
It will always go over every pixel. How else are you to know what the
value of a pixel is?
> I was hoping that now that this function is implemented in C that this
will provide boost in the speed, which it seems that it does in general,
but not for this case.
It was always in C, even in 2.0.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2454#comment:9>
