[postgis-tickets] [PostGIS] #2458: liblwgeom-2.1.0.so not found by loader utilities
PostGIS trac at osgeo.org
Sat Aug 31 13:22:59 PDT 2013
 Reporter:  kentr     |       Owner:  pramsey
     Type:  defect    |      Status:  new
 Priority:  critical  |   Milestone:
Component:  postgis   |     Version:  2.1.x
 Keywords:            |
 Unsure if this is a bug or just my own error in installation.
 After performing documented installation procedure, I received this error
 when executing loader utilities:
 /usr/lib/postgresql/9.2/bin/shp2pgsql: error while loading shared
 libraries: liblwgeom-2.1.0.so: cannot open shared object file: No such
 file or directory
 Discovered that running the command within the build directory, it worked
 as expected (meaning, I got the version / help text output):
 loader/shp2pgsql
 Found that if I copied these two liblwgeom files to /usr/lib, then the
 installed binary also worked as expected:
 liblwgeom/.libs/liblwgeom-2.1.0.so
 liblwgeom/.libs/liblwgeom.so
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2458>
