[postgis-tickets] [PostGIS] #2461: cu_measures.c cleanup unused variables
trac at osgeo.org
Sat Aug 31 18:32:02 PDT 2013
Reporter: robe | Owner: pramsey
Type: defect | Status: new
Priority: low | Milestone: PostGIS 2.1.1
Component: postgis | Version: 2.1.x
Keywords: |
I know these aren't real issues, but the warnings are creating noise on my
compiler output.
CAn we get rid of these unused variables.
cu_measures.c: In function 'test_lw_dist2d_pt_arc':
cu_measures.c:447:6: warning: variable 'rv' set but not used [-Wunused-
but-set-variable]
int rv;
cu_measures.c: In function 'test_lw_dist2d_seg_arc':
cu_measures.c:507:6: warning: variable 'rv' set but not used [-Wunused-
but-set-variable]
int rv;
cu_measures.c: In function 'test_lw_dist2d_arc_arc':
cu_measures.c:580:6: warning: variable 'rv' set but not used [-Wunused-
but-set-variable]
int rv;
cu_measures.c: In function 'test_lw_dist2d_pt_ptarrayarc':
cu_measures.c:685:6: warning: variable 'rv' set but not used [-Wunused-
but-set-variable]
int rv;
cu_measures.c: In function 'test_lw_dist2d_ptarray_ptarrayarc':
cu_measures.c:759:6: warning: variable 'rv' set but not used [-Wunused-
but-set-variable]
int rv;
Ticket URL: <https://trac.osgeo.org/postgis/ticket/2461>
